Logging Load
Old Sep 25, 2006 | 08:49 AM
djd24's Avatar
Logging Load
Can somebody please tell me how I can determine load when analyzing my EvoScan logs?
Old Sep 25, 2006 | 12:22 PM
C6C6CH3vo's Avatar
Download the correct version of Load calc. for your version of EvoScan.
You just drag the excel doc and drop it into the calculator and it farts out the correct load in an extra column, and is dead on too
Old Sep 25, 2006 | 12:25 PM
MalibuJack's Avatar
I like how you worded that.. Farts out the correct load..
But he's correct.. The app works pretty well without having to do it manually in Excel.
Old Sep 25, 2006 | 01:28 PM
djd24's Avatar
Where can I find this Load Calc?
Old Sep 25, 2006 | 02:16 PM
C6C6CH3vo's Avatar
I usually get gas after I press the "digest" option
What version evoscan do you use, v0.8 or v0.9?
Old Sep 25, 2006 | 03:07 PM
djd24's Avatar
v0.9
Old Sep 25, 2006 | 03:27 PM
C6C6CH3vo's Avatar
http://www.aktivematrix.com/forum/dl...ile&file_id=24
Just use the same stuff you use to run the EvoScan and you'll figure the rest out on your own. Any problems you run into getting started likely been encountered so helpful info is either on here (?f=179) or on the Matrix.
Old Sep 25, 2006 | 04:14 PM
djd24's Avatar
Thanks...I'll give it a try.
Old Sep 25, 2006 | 06:48 PM
djd24's Avatar
When I look at my evoscan logs, I see that my ARFMAP column is blank. Why is this?
Old Sep 25, 2006 | 06:54 PM
ant_turbo's Avatar
Question how do you save it as a excel doc ???
Old Sep 25, 2006 | 07:07 PM
MalibuJack's Avatar
Look at the original file, I'll bet its not in the original too.. Its possible its blank because its not enabled.. I have only seen one log submitted to me that had the AFRMAP column there, but blank.. I assumed it was because it was not selected..
Old Sep 25, 2006 | 07:16 PM
C6C6CH3vo's Avatar
That happens to me whenever I accedentally change something to the document.
You need fresh excel logs that have only been viewed and not saved a second time.
You'll get it
Old Sep 25, 2006 | 07:23 PM
djd24's Avatar
Nice call - it wasn't selected. I never even scrolled down in the program to see if it was selected. I also received an error message from your load calculator program...I'm guessing this is because there were no values in the ARFMAP column?
Old Sep 25, 2006 | 07:35 PM
djd24's Avatar
Yup...it works now...i found a file that had the AFRMAP column selcted. Thanks for all the help.
ekizenbe
Sep 7, 2016 12:51 PM
EvilEvolution8
Dec 24, 2015 12:08 PM
okevolutionVIII
Jan 1, 2014 10:15 PM
darksideauto
Lancer Engine Management / Tuning Forums
Jun 13, 2012 05:34 PM
dmoevo
Jan 13, 2010 09:06 AM
