New Ferredo Brakes Squeeking Bad "Help"
Old Jun 14, 2007 | 08:59 AM
lapkin's Avatar
I recently purschased a new set of DS2500s for my rears on stock Brembo rotors.
I unfortunately had to replace my clutch soon after I installed them, leaving my car idle for over 2 weeks, had to wait for parts. Now the rears squeek really bad, did not have this right after I installed them, or previously, just after I started driving again. Did I let them set too long without being "broke in"? I am thinking about using brake cleaner on them to see if that works... any ideas?
Old Jun 14, 2007 | 09:58 AM
GTWORX.com's Avatar
Did you do a bed-in procedure when you first installed them? If not I would recommend it, here's a good writeup on the process.
http://www.stoptech.com/tech_info/wp...formance.shtml
-Dan
Old Jun 14, 2007 | 10:21 AM
19psi's Avatar
-Dan
+1
Also, make sure to apply some anti-squeal on the shims.
Old Jun 14, 2007 | 10:27 AM
DaWorstPlaya's Avatar
1. Bed them in properly
2. Re-use all the shims
3. Use anti-squeel lubricant between the pads and shims.
