Squeaky Brakes!!
Old Jul 12, 2007 | 05:17 PM
MTRJunior's Avatar
Squeaky Brakes!!
Hey guys,
I installed 2 pc slotted rotors and HP+ Pads on my car 2 days ago and went into the highway and did the bedding and cooling down needed, I did everything as instructed by a StopTech rep...but my brakes are squeaking BAD, like metal against metal..and its LOUD, it makes everyone stare at me as I'm stopping for a red light. I doesnt squeak when Im braking at higher speeds...but as the car slows down to around 20-10mph and getting ready to stop my brakes squeak like crazy, its a horrible sound. I've tried searching around and all of that but I'm not sure I have found the right answers, if you guys could help me out that'd be great. Thanks in advance!
Old Jul 12, 2007 | 05:43 PM
Tuner@Swift's Avatar
Did you reuse the shims that are glued to the back of the stock pads? If not, then you'd better find some.
Old Jul 12, 2007 | 05:48 PM
evrblazin's Avatar
and you need a good amount of high-temp grease on the shims too
Old Jul 14, 2007 | 08:58 AM
grillpt's Avatar
Welcome to the wonderful world of Hawk brake pads...
I have the HPS, I used BG stop squeal, bedded them correctly, and they still make a lot of noise. It's just the price we have to pay... It will subside some, but they will always make noise, no matter how many times you bed them.
Old Jul 14, 2007 | 01:33 PM
MTRJunior's Avatar
i have no problem with a bit of noise...but is drilling through your ear painful squealing normal with these pads?
Old Jul 15, 2007 | 09:22 AM
HaVoC RR's Avatar
i have stoptech 2 piece and hawk hps as well
its a hawk trait.. it squeal's like a pig..
and i used factory shims and hi temp grease
Old Jul 26, 2007 | 08:33 PM
MTRJunior's Avatar
alright, I made sure the shims were on there...put a good amount of high temp grease and everything! but it still squeals...anyone know any better pads to use than the hawks?
Old Jul 26, 2007 | 08:51 PM
suekie's Avatar
all higher performance break pads are going to squeek at low speeds. Even the stock pads on the EVO sometimes squeek. So the break pads arent bad.
Old Jul 26, 2007 | 09:23 PM
badboybr09's Avatar
yea I got my Hawk HPS Perfomance pads, they squeaked in the beginning, so I thought it was normal since they were still gettting used to the rotors.. its been a month already and they are still squeaking so Im assuming its normal since theyre High Perfomance pads.
Old Jul 26, 2007 | 10:01 PM
MTRJunior's Avatar
id be fine if they were just squeaking...they are abnormally squeaking like anything Ive ever heard before...like a loud SQUEALing sound ... btw, I have the HP+ and not the HPS...so that might be the reason for this...Im gonna put more grease on the front pads since it seems to be the place where most of the noise is coming from...I put a generous amount in the rear pads and they dont squeal...but when I got to the front I didnt have as much grease left.
Old Jul 26, 2007 | 10:10 PM
badhabit90's Avatar
Cool
DO NOT PUT ANYTHING ON THE FACE OF THE PADS!!! this is just a trait of the HP+ pads. read, read, read, and search some more and you will find that this is common. it is a trade off for performance at higher speeds.
Old Jul 26, 2007 | 10:36 PM
MTRJunior's Avatar
im obviously going to put grease ON THE BACK of the front pads
Old Jul 27, 2007 | 07:27 AM
derangedazn's Avatar
Hahaha well from the way you wrote that previous post I was thinking the same thing...why is this dude going to put grease on the front of the pads....lol
Old Jul 27, 2007 | 12:03 PM
k20ep3's Avatar
Just deal with it....once you drive your car hard and see how well they perform you will have econd thoughts about replacing the pads.
Old Jul 27, 2007 | 12:20 PM
GTWORX.com's Avatar
If you guys are looking for just a quiet, dust free, OEM replacement pad, try the Stoptech/Centric Parts Posiquiet ceramic pads. Very quiet, very dust free, and only 100 bucks shipped for a front and rear set. Performance is about the same as stock, which is pretty close to Hawk HPS. Not quite as good as Hawk HP+ though.
I personally have never had an issue with Hawk HPS making noise and i run them on my own car, but it seems everyone else in the world has.
- andrew
Bhsj13
13
Apr 5, 2017 04:26 PM
TxFAkuma
45
Feb 24, 2017 05:19 AM
mitsuevodriver
Feb 22, 2010 01:50 AM
LooneyToon
May 11, 2009 05:25 AM
Ralli04
May 7, 2007 05:29 PM
