Lancer How To Requests / Questions / Tips If you have any questions, post them in here.
blinker bulbs
Old Oct 31, 2007 | 08:00 PM
mines hotter's Avatar
blinker bulbs
hey does any one know of a sight where i could get the front blinker bulbs ive googled WY21W and just keep getting crap and all i want are clear or blue bulbs
Old Nov 1, 2007 | 10:28 AM
Blacksheepdj's Avatar
eBay? There's usually a decent bulb selection there.
Old Nov 1, 2007 | 08:29 PM
mojeorliy's Avatar
The wy21w type bulbs are the same as 7443, with this number you will find the right bulb easy. Ebay have a lot for your selection, specially leds if you want some new style.
Old Nov 1, 2007 | 08:50 PM
o okay thanks alot do you think iwill have a problem with l.e.d blinkers i heard some one had no trouble but i wana be sure
Old Nov 2, 2007 | 05:41 AM
Eagles GTS's Avatar
You have to install load resistors for each led you put in. The leds draw too little power compared to the OEM bulbs and the leds wont work. The load resistor lowers the power. Here is a site where you can get everything lighting you need for your car- http://autolumination.com/194.htm. Make sure you scroll down to see everything.
Old Nov 2, 2007 | 02:23 PM
mojeorliy's Avatar
another page: www.superbrightleds.com or the ebay store V leds
Old Nov 2, 2007 | 02:25 PM
mojeorliy's Avatar
The leds will work without the load resistors but will blink to fast because the car will understand that you have a burn bulb, all because the draw too little power like eagles gts sayd.
Old Nov 2, 2007 | 04:55 PM
ic ic well i ordered l.e.ds for my parking lights and liscens plate lights i should be fine with those right?
Old Nov 2, 2007 | 06:14 PM
SpeedI2acerX's Avatar
also when you gets those bulbs THEY DO FIT first time i got them i was like wtf, went back and exchange them until the 3rd time. yeah it doesnt look like they fit but keep trying, they doooooh
Old Nov 2, 2007 | 06:54 PM
Eagles GTS's Avatar
you will need a load resistor for each led you install in a flashing socket like turn signals
Old Nov 2, 2007 | 10:30 PM
Hawkeye's Avatar
There may be a way to bypass the load resistors by modifying the flasher unit. I've done it on some other makes and it is a working project of mine.
Old Nov 3, 2007 | 05:41 AM
Eagles GTS's Avatar
never heard of it but whatever is easier is the way i would go
Old Nov 3, 2007 | 03:29 PM
mojeorliy's Avatar
Wow if you can modify the module and bring the idea in an easy way that anyother can do it, you are the pro
Old Nov 4, 2007 | 04:49 PM
Bradley_J's Avatar
I ordered sylvania silver bulbs from europe. They are mirrored in color, but light up amber. They matched the bulb type and work perfectly. Plus there is no amber color in my lens, and they don't require a resistor.
Old Nov 5, 2007 | 06:01 AM
Eagles GTS's Avatar
I dont know why I didnt think of those bulbs. I am going to shop around, where and how much for yours?
