Basic Evo X ROM XML definition
Old Oct 12, 2008 | 05:17 PM
gunzo's Avatar
Basic stuff .. now trying to figure out why there's 2 VVT maps .. 2 for intake and 2 for exhaust ..
You can get the ROM image from openecu.org ..
The EUDM and JDM are similar .. The USDM is SM5628 I think ..
Please RENAME the file to SM5236.XML
getting exciting ..
Oops .. it's written in ECUflash 1.29 .. endian thingy .. simple fix to view
NOTE: the XML is for viewing only !!!
Once the ECUflash is released, this XML will be replaced with a functional XML !!
Old Oct 12, 2008 | 06:31 PM
DVDee's Avatar
Ecuflash 1.29 is two years old. I'm sure you mean 1.39.
Old Oct 12, 2008 | 08:52 PM
gunzo's Avatar
1.29 ..
I like stable software .. that's the most stable I've used so far ..
Old Oct 12, 2008 | 09:48 PM
Guru's Avatar
I would assume for low and high load.
Old Oct 13, 2008 | 02:56 PM
mrfred's Avatar
getting exciting ..
This is for a JDM GSR or JDM SST?
Old Oct 13, 2008 | 04:48 PM
gunzo's Avatar
SM5236 is manual GSR
SM5237 is SST GSR
Old Oct 13, 2008 | 04:51 PM
DVDee's Avatar
I couldn't find the rom files on openecu. Can you post the USDM file here?
Old Oct 13, 2008 | 05:14 PM
SiC's Avatar
SiC
Thanks! I got it to work with the JDM GSR rom.
Old Oct 13, 2008 | 05:33 PM
gunzo's Avatar
anybody with a server or know a place for the ROM ??
SiC FINALLY .. I'll update you as and when I finish disassembly on each section of the subroutines ..
Old Oct 13, 2008 | 05:38 PM
gunzo's Avatar
Good assumption .. It looked like 1 is for cruising .. the mivec changes are concentrated between load range 60-120 and rpm 1750-3000 band
Old Oct 14, 2008 | 10:23 AM
mrfred's Avatar
gunzo, might be a good idea to update the xml file for the correct <flashmethod> attribute.
Old Oct 14, 2008 | 11:07 AM
RazorLab's Avatar
Here is a USDM XML, still working on it, tables moved over from your XML gunzo so I am still finding some the USDM addresses.
File Type: zip
Old Oct 14, 2008 | 12:04 PM
08EvoXGSR's Avatar
nice find-1.29 FTW!
Old Oct 14, 2008 | 01:22 PM
Seb's Avatar
Seb
So does this mean Open Port 2.0 works with ECU Flash now?
Anyone have a bin file to upload?
thx
Old Oct 14, 2008 | 02:34 PM
mrfred's Avatar
thx
ECUFlash for the X is in beta. A public release will follow, probably within two weeks.
