How does the ECU determine load?
Old Jan 10, 2009 | 01:02 AM
madcows's Avatar
I've been searching this subject for a few days now, but couldn't find anything on it. Hopefully it hasn't been right beneath my nose.
I've asked this in other threads as well, but never got a definite answer. I'm just trying to understand how the ECU determines the load. Anyone know the calculation taking place?
Old Jan 10, 2009 | 11:30 AM
mrfred's Avatar
Load is airflow per engine revolution.
Old Jan 10, 2009 | 01:21 PM
madcows's Avatar
What unit does it use for airflow?
Old Jan 10, 2009 | 04:57 PM
mrfred's Avatar
Some people say that the units are in kPa, but I've never seen anyone do a formal analysis of the code to prove it.
Old Jan 10, 2009 | 05:05 PM
SiC's Avatar
SiC
I always thought it was a combo of MAF & MAP readings.
Old Jan 10, 2009 | 05:17 PM
mrfred's Avatar
Its only MAF.
Old Jan 10, 2009 | 05:20 PM
madcows's Avatar
So the load numbers directly correspond to these calculations?
Old Jan 10, 2009 | 05:25 PM
madcows's Avatar
Its only MAF.
Do you know if the ECU is using the MAF values to determine the amount of fuel to achieve the desired A/F ratio, or is it using the map sensor?
Old Jan 10, 2009 | 05:28 PM
mrfred's Avatar
On the Evo 1-9, its only MAF to determine airflow for normal conditions. The JDM Evo 9 will use its 3 bar MAP to determine airflow in a limp home situation, e.g., intercooler pipe blows off or MAF sensor dies. For the Evo X, its likely the same as the JDM Evo 9, but this is TBD.
Old Jan 10, 2009 | 05:37 PM
madcows's Avatar
That bring up a quick question: what are the specs of the USDM map sensor?
Old Jan 10, 2009 | 05:39 PM
mrfred's Avatar
The USDM Evo X MAP sensor is a 3 bar unit. Its the exact same sensor that's on the JDM Evo 9 and X. USDM Evo 8/9 have a 1 bar MAP sensor.
Old Jan 10, 2009 | 05:40 PM
gunzo's Avatar
Mychailo, are you working on the IDA I sent you or you generated another using the USDM ROM ??
If you're using mine .. pm me your email and I'll send you my updated IDA .. its not the 5268
Old Jan 10, 2009 | 05:49 PM
madcows's Avatar
If it uses the MAF, then under normal conditions, what is the MAP used for? I'm trying to get a better understanding of the implementation of it's systems.
Old Jan 10, 2009 | 05:54 PM
mrfred's Avatar
I decided to start from a USDM GSR ROM. I thought there might be enough similarity to a USDM Evo 9 algorithms to improve the rate of comprehension of the Evo X code. So far, I think its paying off.
Besides the limp home feature likely now implemented on USDM Evo Xs, the MAP sensor is used to judge (not control) EGR system performance. On the Evo 8/9, judging EGR system performance was the only purpose of the 1 bar MAP sensor.
Old Jan 10, 2009 | 06:30 PM
madcows's Avatar
I'm not trying to get into a product discussion/argument, but since the ZChip modifies the MAP signal to change performance, wouldn't that mean the MAP sensor must be doing more than what you described?
