Tuning questions
Old Jan 21, 2009 | 10:11 AM
wado's Avatar
Tuning questions
I've been reading the threads and trying to get a realistic idea of what to expect for HP gains out of these cars. I see a great number of products out there and I guess my question is what products really produce the most HP/bang for the buck. I'm thinking I'd like to hit 350 RWHP but i don't want to break the bank and I want a rock solid dependable car as this is my daily driver. So access port, tune, pill?, exhaust?, cold air intake? what should I be looking at?
Old Jan 21, 2009 | 10:31 AM
Shabarivas's Avatar
Hope you mean 350AWHP ;p
AP + pill (or MBC) + drop in filter + exhaust + down pipe + tune will get you very close is my guess... worst case add on a FMIC and IC pipes and should put you north of 350 for sure ... but then again depends on the tuner
Old Jan 21, 2009 | 04:28 PM
seeevo's Avatar
hmmm how much will all this end up costing?
Old Jan 21, 2009 | 06:02 PM
Mad_SB's Avatar
Best bang for the buck is a tune without a doubt. You should see 50 - 60 whp gain from custom tuning alone with no after market parts.
3" turbo back will run in the 1,000 to 1,500 and is good for another 10-20 whp peak but lots of area under the curve
Upper IC pipe figure 150 - 350 depending on brand and may bee good for up to 10whp
Drop in filter will run 50 - 100 and depending on brand could net 0 - 10 whp
With all of the above you would be in the 295 - 310 whp range on an uncorrected dynodynamics. Or 343 - 360 whp on a typical dynojet.
At this point you will be out of injector and need to start looking for fuel system upgrades.
Save yourself a little money and get all the hard parts purchased and installed before your tune.
Old Jan 21, 2009 | 07:17 PM
dcasandman's Avatar
I have just about all the bolt-ons now minus a intake (I do have HKS dropin). My car made 341whp on a mustang dyno with a custom tune with the AP at Cobb Tuning in Plano, Tx. I do have a Pill and my boost peaks at 27 and tapers to 21-22.
Old Jan 21, 2009 | 07:38 PM
John83's Avatar
Really? I've noticed smoother power while untuned; my butt dyno says 2.33333 WHP
I wonder if this part on a tuned car would actually make a noticable difference.... ?
Old Jan 22, 2009 | 03:01 AM
Mad_SB's Avatar
True, I said up too 10whp so it could be as low as 0 and as high as 10 whp I picked up about 10whp between the filter and the hot side Intercooler Pipe.
Old Jan 24, 2009 | 03:49 PM
adamweldonjohns's Avatar
There's a thread on these forums called something like modding your evo $100 at a time or something like that - very good thread if you're on a budget.
