Anybody have the Stage 2 93oc Map?
Old Feb 4, 2009 | 07:16 PM
Red08EVO's Avatar
I just downloaded the stage 2 93 oc map to my accessport. Now just waiting for my tbe. It requires to remove the pill restrictor also. Anybody else running this map? Any feedback from personal use?
Old Feb 7, 2009 | 11:36 PM
bigmiketino's Avatar
Yes i installed the map today.I took out that pill.The runs good.
Old Feb 8, 2009 | 02:00 AM
LVSBB6's Avatar
Has anyone dyno'ed this map?
Old Feb 8, 2009 | 07:53 AM
smoothevo's Avatar
Are you getting a cell (check engine) or was that fixed?
Old Feb 8, 2009 | 08:23 AM
Rob@cobbtuning's Avatar
We have a fix for the P0420 that we will be putting into all our stage II maps very soon. The fix is currently being beta tested and seems to be working like a champ.
Thanks,
Old Feb 8, 2009 | 11:44 AM
smoothevo's Avatar
Thanks,
Sweet thanks Rob - now I just need you to release the exhaust
Old Feb 8, 2009 | 01:15 PM
goofygrin's Avatar
Awesome, thanks Rob!
Here's my dyno of a modified stage 2 map (from a dyno tune)
Just putting the stage 2 map on there resulted in slightly lower gains, but there was some leaning at the top RPM range. If you have a wideband keep an eye on it.
Old Feb 8, 2009 | 01:24 PM
Q15H's Avatar
If the stage 2 map is installed without removing the boost pill the boost will be lower, right?
Old Feb 8, 2009 | 01:30 PM
ZWingerRyRy's Avatar
Stage 3 From Perrin w/ AP
Only Perrin FMIC and Turboback(br catback+perrin dp/hiflo cat combo pipe) No boost pill mod. My gauge read 27psi, theres read 25.0. Perrin says 26.86psi
For comparing needs. Was on 92oct, map was for 93oct. opps
Old Feb 8, 2009 | 02:04 PM
ChEvo8's Avatar
nope
Old Feb 11, 2009 | 05:11 PM
Red08EVO's Avatar
can you run stage 2 with just a dp and stock cat and catback?
Old Feb 11, 2009 | 06:10 PM
goofygrin's Avatar
why waste your money on a worthless downpipe? The cat, catback and o2 housing are where the gains are in the exhaust until you get to a bigger turbo.
Old Feb 11, 2009 | 06:32 PM
Red08EVO's Avatar
correct me if im wrong. i thought cobb calls for a 3'' dp to run stage 2 map?
Old Feb 11, 2009 | 06:34 PM
goofygrin's Avatar
From the map notes: http://www.accessecu.com/accessport/...%20GSRv100.pdf
Intended for an otherwise stock
2008 Mitsubishi EVO GSR vehicle with full turbo back exhaust
system.
A downpipe does not a TBE make.
Old Feb 11, 2009 | 06:39 PM
Red08EVO's Avatar
a 02 housing is nesscary too?
