ECUflash and WORKS flashed ECU
Old May 9, 2009 | 08:31 PM
nj1266's Avatar
I have flashed Evo Xs 45 times, test flashed Evo 10s another 45 times, and read Evo X ECUs another 5 times. In total I have used ECUflash on Evo 10s about 95 times.
Today a friend of mine wanted me to read his WORKS flashed ECU. Boy was that a mistake.
The moment I try to read the rom, ECUflash gives me a J2534 error and closes the interface. The car stays in flash mode with the fans engaged and the dash lit up. Needless to say the car will not start.
So we flatbed the car to the shop that uses WORKS flashes and hardware/software interface.
They connect their hardware and use their software to flash the car and all is fine. The ECU is re-flashed and the car starts again.
Here are my questions:
1. Did this happen because WORKS has changed the interface when they flashed the ECU?
2. Did WORKS lock the ECU and not tell my friend?
3. Is this ECUflash related. Mind you, this has NEVER happened on the 95 flashes that I have done on Evo Xs.
I really want to know why this happened. I hope it is not ECUflash related.
Old May 9, 2009 | 08:35 PM
Wicked E's Avatar
If I recall correctly Naji, Works does lock their flashes. I could be having a memory lapse though and be completely wrong. Wouldn't be the first time...
-E
Old May 9, 2009 | 08:42 PM
nj1266's Avatar
-E
Thanks for refreshing my memory. I recall that an Evo 8 of a dear friend of mine had a P2 flash and had the ECU locked. The tuner had to use MalibuJack's ECU unlocker tool to read/re-tune the ECU.
That was on an Evo 8/9. It is entirely possible that they are still doing it on the X.
Old May 9, 2009 | 08:48 PM
Noize's Avatar
EvoM Administrator
No mainstream third party unlock for X yet.
EcuTeK is not locked this time around, WORKS is.
Old May 9, 2009 | 08:54 PM
HB Speed's Avatar
Works are Locked....
but it wont mess the car up if you try to read it
you have to use the exit programming state, then all is well....
I personally can read / write over them, but its not public knowledge
Old May 9, 2009 | 09:03 PM
SpeedI2acerX's Avatar
Yeah its was me that it happened to. I wish Works could have told me or gave me a warning not to touch or try to read the ecu.
And...it did mess up my car just trying to read it. Car went into "limp mode". the fan came on and would not start, we tried everything.
Now im "stuck" with Works and have to schedule something with Works and EDO to have my car looked at if i have to reflash or re-tuned my car.
Old May 9, 2009 | 09:05 PM
HB Speed's Avatar
No, you dont.
We can retune and reflash your car At will.....
drop me a pm and i can tell you your options.
Old May 9, 2009 | 09:18 PM
nj1266's Avatar
If HB Speed can do it, then go for it. But make sure that he will NOT lock your ECU. Have him put it in writing so you will not have to go through the crap that you and I went through today.
Old May 9, 2009 | 09:29 PM
Originally Posted by HB Speed
No, you dont.
You got PMed
Old May 9, 2009 | 09:36 PM
HB Speed's Avatar
If I can repair bricked X ecu and I can read ANY flash and flash over ANY flash I'm pretty sure he will be safe.
Old May 9, 2009 | 09:38 PM
HB Speed's Avatar
Speed my bb can't reply to pm
Emal me from my site!!
Old May 9, 2009 | 09:42 PM
Wicked E's Avatar
That's one thing I hate about my BB... Pisses me off...
Old May 9, 2009 | 09:43 PM
I just sent you an email through your site let me know if you got it. thx
Old May 9, 2009 | 09:46 PM
HB Speed's Avatar
I've got the admin workin on that
Luckily one is a friend
Old May 9, 2009 | 09:50 PM
nj1266's Avatar
That is not the question. The question is this: Are you going to lock his ECU after you tune the car with ECUflash?
