Help can't adjust stationary rev limiter
Old May 12, 2009 | 01:15 AM
hawaiian_evo's Avatar
like the title says I can't seem to adjust my 2 step...
I downloaded my rom to my computer and adjusted the stat. limiter to 5500...
then I reflashed my car to test the 2 step and still at 6500...( I'm not gonna launch it at 6500 haha)
I went over the basics
-car isn't moving at all
-clutch is pressed in all the way
-checked all plugs everything seems to be in..
am I doing something wrong? I know 6500 isn't my rev limiter I did adjust my rev limiter to 2k just to make sure it works and it does. ( I set my rev limiter back to 7900 after)
I redownload the rom and open the stat rev limiter which reads 5500. so I'm lost I don't understand why I can adjust my rev limiter but not my stat limiter
sorry if this thread is confusing I'm typing it up on my phone
Old May 12, 2009 | 02:44 AM
burnings's Avatar
did u engaged 1st gear and hand brake is off?
Old May 12, 2009 | 03:01 AM
yes i did
Old May 14, 2009 | 04:18 AM
does anyone have a stock 2008 evo x gsr rom they wouldnt mind sending me?
Old May 14, 2009 | 07:39 AM
WarmAndSCSI's Avatar
Here is my stock one, http://mitsubishipowered.com/downloa...20Original.hex
It's one version behind, 52680017 versus the new 18 one.
Old May 14, 2009 | 07:46 AM
joehoo's Avatar
what good is having a 2 step if you not going to use it?
Old May 14, 2009 | 07:49 AM
thanks warmanscsi
Old May 14, 2009 | 08:09 AM
idk never said i wasnt gonna use it just dont want to launch it at 6500k
Old May 14, 2009 | 08:10 AM
Mine was at 5500 stock... that's what you're getting at I guess.
Old May 14, 2009 | 09:48 AM
yes 5500 or 5800 would be max target for a launch idk 6500 soounds like it will do some damage
Old May 14, 2009 | 03:57 PM
ok just tried this rom and i got basically the same thing. The only difference is the stat limiter is now at 5500 (stock). Even if i try to change the limiter nothing happens.
So im out of ideas... I was going to transfer all my tunned rom data to the one above but im afraid it wont work like the stat limiter.
any ideas guys i want to try and fix this because i have a track day comming up on sat
Old May 14, 2009 | 04:42 PM
my rom id is 52680018 and my stat rev limiter address is 53442
can anyone verify with the same rom id the stat rev limit address or does anyone know how i can find the correct address (assuming this is the wrong address)
mahalo
Old May 15, 2009 | 01:28 PM
bump for some help
Old May 15, 2009 | 04:14 PM
mrfred's Avatar
mahalo
I just looked at the code where this value is used. It does not appear to have anything to do with the stationary rev limit. Has anyone *successfully* changed their stationary rev limit yet, and if so, what's your ROM ID?
Old May 16, 2009 | 03:05 PM
hmmm anyone got there 2 step working?
