Cobb AP reading low boost
Old May 25, 2009 | 08:14 PM
sgtpruitt's Avatar
Is there a reason my AP only reads 5.8 PSI when monitoring boost pressure?
I just did UICP and TBE but do not believe I have a boost leak. Also the car is pulling harder then ever so it doesn't feel like i'm losing boost.
I'm check for a boost leak in the next few days but I was wondering if this was AP specific or I am just monitoring with the wrong option.
I'm running the Cobb stage 2 map for ACN btw.
Old May 25, 2009 | 09:20 PM
goofygrin's Avatar
do you have the beta firmware? It's the only one that supports reading the correct "relative pressure" (i.e. boost) numbers.
Old May 25, 2009 | 09:29 PM
sgtpruitt's Avatar
ohhhhhh, no I don't believe so. I just got it and updated the firmware to the latest version. I have to assume that is not the beta.
Well that is good to hear, sort of. Thanks for the response.
Is there a way I can revert to the beta firmware some how, some way.
Old May 25, 2009 | 09:47 PM
Young HigH's Avatar
go to the AP updater then click tools then there is 2 boxes on the top for beta options
Old May 25, 2009 | 09:50 PM
Freebs's Avatar
Not to jack this thread but where do I look to see my boost pressure? every one I click on is showing numbers that couldnt be my boost pressure.. and yes I have the update
Old May 25, 2009 | 09:52 PM
Young HigH's Avatar
Rel Boost is supposed to be the boost.
Old May 25, 2009 | 10:05 PM
Freebs's Avatar
I will have to look again but the other night when I hooked it up I couldnt find anything for engine boost
Old May 25, 2009 | 10:09 PM
Young HigH's Avatar
oh ok with the latest firmware Real Boost= engine boost as per cobb's website
Old May 25, 2009 | 11:45 PM
sgtpruitt's Avatar
Got it. Thanks a lot. 25.x psi on stage 2 btw.
Old May 26, 2009 | 07:04 AM
Young HigH's Avatar
No Problem
Old May 26, 2009 | 10:28 AM
Methodical4u's Avatar
yep, mine was reading 5.8 too
Old May 27, 2009 | 07:23 PM
GGIXMRSE06's Avatar
Keep this thread alive. Make sure to post a update when a fix is found.
Old May 29, 2009 | 02:54 AM
ApexSilverXGSR's Avatar
I was wondering the same thing with mine. what's absolute pressure then? i get 5.8 boost pressure and it'll go up to as much as 27psi in abs pressure for stage 1 93 octane... wth does that mean?
I really hope I didn't just spend hundreds of dollars to get something that isn't operating up to par... can anyone clarify this?
Old May 29, 2009 | 04:23 AM
Young HigH's Avatar
you have to update to the BETA FIRMWARE. open the AP updater the then click tools then and options tap should pop up then on the very top there are 2 beta options check both of them. now your AP is updated with the beta firmware that reads boost. REL BOOST = Boost.
Old May 29, 2009 | 11:33 AM
Tunerhead's Avatar
Absolute Pressure = absolute boost pressure (ambient+relative)
