cobb AP for two?
Old May 28, 2009 | 01:28 PM
novaspyder87's Avatar
cobb AP for two?
Hi, I would like to know if its possible to buy only 1 cobb ap....and tune 2 cars with it? if not, what stop you from tuning 2 cars with one AP?
Old May 28, 2009 | 01:36 PM
goofygrin's Avatar
the AP "marries" itself to one car.
2 cars = 2 APs required.
Old May 28, 2009 | 02:14 PM
COBB Tuning's Avatar
Like goofygrin said, the AP will only work on one car while it is installed on that car. The AP can be uninstalled and used on another car if you decide to sell the unit, for instance, but then the AP flashes your car back to stock during the uninstall process. This is intended to prevent multiple users from using one unit.
Travis Geny
COBB Tuning
Old May 28, 2009 | 02:35 PM
thank you very much....its normal. If it wasnt working like that you would loose a lot of money. tks again
Old May 28, 2009 | 03:22 PM
mike100's Avatar
You might want to look into open source EcuFlash tuning if you want to split the cost with a friend.
Old May 29, 2009 | 05:06 AM
dek0026's Avatar
the AP is faithful to only one car at a time. it has to break it off with one car to get with another.
Old May 29, 2009 | 06:43 AM
ugakirk's Avatar
But what about the shops that tune with the AP? If you create your own maps can you install it on more than one car?
Old May 29, 2009 | 08:51 AM
Mad_SB's Avatar
Ap is designed to deliver the tunes to your ecu. The ap hardware marries to the ecu. Maps can be added and removed from the ap, but the ap will always only be able to flash the maps to the car it is married to.
tck253
May 27, 2015 10:15 AM
menace1
Jan 27, 2015 04:40 AM
anthony penn313
Mar 23, 2012 06:37 PM
an2ny
Cobb AccessPORT
Oct 17, 2011 05:58 AM
sideway180sx
Apr 24, 2011 06:51 PM
