Map Tracing on EvoScan v2.6 ?
Old Aug 31, 2009 | 04:43 PM
Live4Redline's Avatar
Alright well the evoscan is linked with ecuflash with the intended effect to allow you to now map trace.
I've been playing with it and so far I've gotten it to do a Map Tracing Replay from the Sample log file but that's about it. I've haven't been able to get it to work on one of my own logs (recorded within v2.6) or in real time at all. Has anyone played with this or figured it out yet?
For the guys who haven't had a chance to take a look at it and plan on doing so here's the crash course to get to where i am now...
Open up Evoscan and at the top click the "Graph's & Map Tracer" menu. Select either "Real Time Logging" and then "Map Tracer" at the bottom [OR] "Analyze Log File : Map Tracer" for a more direct route. Now choose the log file "Sample1" and when the window loads go to the bottom map window and RIGHT CLICK to select a ROM FILE. You can also change from Fuel Map to Ignition Map by right clicking the bottom window. Now select the field from the left that you would like to have map traced and the results will be displayed in the top window.
Its not real time but it'll get the job done so long as it'll work on log files other then the samples.
Any other insight on the mater would be very appreciated.
Old Aug 31, 2009 | 05:41 PM
Search Button Failed Me: Did four searches and found nothing, then Google pops this up an hour later....
https://www.evolutionm.net/forums/ec...ap-tracer.html
But even so... my issue is that the log is not reading. The rom loads and displays fine. The sample works just nothing that i've recorded my self. And I've tested it on a log with everything selected. I don't get any messages or error codes just nothing displays up above.
Old Jan 20, 2010 | 11:54 PM
And's Avatar
And
did you resolve this? I have the same problem?
Old Jan 21, 2010 | 07:19 AM
fostytou's Avatar
EvoM Community Team
1 post per minute over 3 minutes? Nice work!
https://www.evolutionm.net/forums/7078367-post16.html
Burnhad91
Jun 2, 2016 06:35 AM
evo4mad
May 5, 2015 06:22 PM
kwboost
May 12, 2014 06:29 PM
Miller_x
Feb 10, 2012 02:12 PM
goevox
Mar 9, 2010 06:42 PM
