Can bad fuel cause knock at cruise but not at WOT?
Hi Guys,
So I have been playing around with my cruise timing to get better MPG and all of a sudden I am hitting HIGH knock counts (think 10+, sometimes 17) at cruise... WOT is ok!
Is it possible a bad batch of fuel will cause knock @ cruise but not at WOT?
Cheers
D.
Cheers
D.
Hi Guys,
This weekends 400 mile trip I had little to know knock(1 count here and there) in all my power band, and then I come back to Utah, and put another tank of 91 in, and I start to knock a little bit in the mid(1-2 count @ 2.5k~3.5k), more so than the Petrol purchased out of state at the same level.
update - filled up from my regular and still get KS spiking to 11 sometimes...
still ok during WOT thou...
I am going through the knock code on the X now, trying to see if there are any hidden variables that might be being introduced..
I am thinking maybe an ECU reset will fix it ... keeping in mind the X ECU doesn't reset like the IX ECU after a reflash!
At what load are you seeing this? I remember someone saying how noisy the motor is in vacuum but it shouldn't be an issue. I would assume there is a reason even mitsu ignored noise under a certain load.
mmm...
btw it all started after two events:
1) installed 3port
2) hit boost limit fuel cut
Now I have un-mounted the 3port from the chassis just incase it was clicking->knock..
Could I have broken anything by hitting boost cut???
1) installed 3port
I have experienced boost cut on numerous times in numerous cars, of course none in an X. I have yet to see any permanent damage. Unless it put the ecu in a safer mode that is causing issues?
