LED DRLs
The socket for my actual low beams wasn't being used, because I went with a relay to the parking lights for my HID Low Beams, since the DRL current from the socket will mess up my HID ballast. So basically my corner lights switch also turns on my Low Beams.
Always planned on hooking up a set of foglights inside the grill, and using the unused low beam sockets as the power source. But I went this route, after seeing someone try something similar.
I was thinking of using silicone sealant. I'm in texas, and I've had some issues with 3m double sided tape in the past sliding off when stuck to plastic. Since the temps in the summer reach close to 105°F, not to mention my car is black.
