Help me to identify this connector
Old Sep 18, 2009 | 02:19 PM
Danieln's Avatar
Help me to identify this sensor connector from the IM
Old Sep 18, 2009 | 02:28 PM
recompile's Avatar
Congrats, you have an IAT sensor :-)
I wish I did
Old Sep 18, 2009 | 02:30 PM
laramie_05MR's Avatar
Intake air temp sensor?
Old Sep 18, 2009 | 02:37 PM
Danieln's Avatar
Yeah I know this
My issue is about the connector
There is a big difference between a GM IAT sensor and this sensor
I have GM IAT with pigtail but this sensor is much smaller is size.
I need to find the connector for this
Same problems MAP and IAT connectors.
Old Sep 18, 2009 | 02:39 PM
Danieln's Avatar
This is the sensor
and connector
Old Sep 18, 2009 | 03:13 PM
Resi's Avatar
I believe that is an OEM mitsu AIT sensor that comes on non-US vehicles. The gm sensor, as you know is larger, as is the connector
Old Sep 18, 2009 | 03:19 PM
Danieln's Avatar
Yes this is a Japanese intake manifold from a IX GT
In order not to drill my manifold to install a MAP sensor I decide it to change it with this one.
The bung is much smaller in order to swap a GM sensor in unless I will drill to fit the GM.
First thing is to find somehow the connector for this sensor.
I am sure that some other available sensor can use this connector too but until now I did not find it.
Old Sep 18, 2009 | 03:29 PM
Danieln's Avatar
I was looking through the wiring diagram for this sensor and it seems that the AIT sensor on the stock harness leads to the same pin (72) for the intake temp but the sensor ground goes to the MAF ground.
I must check this anyway further
Old Sep 19, 2009 | 03:47 PM
todd6027's Avatar
same connector and sensor is used on colt/lancer 1.3, 1990-2000 try your nearest car dismantler/breaker if you cant locate one drop me an e mail .
Old Sep 19, 2009 | 11:58 PM
Danieln's Avatar
thanks for the hint Todd
I will start to look M8
EV09AWD
Aug 7, 2017 01:43 AM
Sanchess
Jul 10, 2017 04:41 PM
evo.matt
Apr 3, 2017 09:48 PM
coolmiro13
Jul 3, 2016 06:33 PM
nolimits1320
Jan 15, 2014 07:55 PM
