LTFT/STFT question
Old Nov 15, 2009 | 09:25 AM
xhomm02's Avatar
LTFT/STFT question
I found something really strange with my EVO X:
When I log my fuel trims during a long cruise (like 100km), I see LTFT in -0,25 to -3% range.
When I sum LTFT + STFT (to get total correction) in all closed loop rows and then I calculate average from all these total corrections, they are POSITIVE cca +3%!!!
How is it possible that average LTFT and average total trim are on opposite sides of zero?
I know that ECU calculates LTFT each few minutes - is the calculate value average STFT from the last period?
Thank you,
Martin.
Old Nov 15, 2009 | 10:48 PM
tephra's Avatar
What do you mean "closed loop rows"?
LTFT's are first "binned" by MAF_Hz's
So basically the ECU has 3 bins, low, mid, high.
When the MAFHz crosses pre-configured barriers the ECU activates a certain LTFT.
Now every few minutes the ECU looks at the current STFT and says - "I am adding 5% fuel, I *should* really add this 5% to the LTFT that i'm currently on"
Since LTFT affects fueling BEFORE the STFT is read/calculated you should realise that STFT is based UPON the LTFT. ie if your LTFT is +5% and your STFT is +5% (average) then eventually the ECU will set the LTFT to +10% (or near enough)
Old Nov 16, 2009 | 01:54 AM
xhomm02's Avatar
"closed loop rows" - I mean I used in Excel only those rows of my log that were logged while the engine ran in closed loop
What I do not understand from my log is that when I calculate average from all trims, I get a little bit positive value (like +3%), but all my LTFTs during cruise are a little bit negative.
Old Nov 16, 2009 | 01:55 AM
xhomm02's Avatar
I only see 2 diffrent number - for idle (and VERY low load) and for the rest
Old Nov 16, 2009 | 11:05 PM
tephra's Avatar
don't average out all the trims.
they aren't long -> longer -> even longer averages. they are MAFHz's bins..
Old Nov 17, 2009 | 11:16 AM
xhomm02's Avatar
It looks like we do not understand each other.
I wonder why average of all trims is positive, while ALL LTFTs are negative numbers.
Old Nov 17, 2009 | 03:41 PM
tephra's Avatar
post up a log and highlight what u mean
ecktt
May 8, 2017 06:18 PM
hkumar
11
Sep 9, 2013 07:55 PM
ethan169
Sep 9, 2011 01:51 PM
AlwaysinBoost
Sep 23, 2010 12:30 PM
nj1266
125
Jan 12, 2010 07:37 AM
