Need some help with reading stock rom
Old Nov 20, 2009 | 10:35 PM
Ah10's Avatar
recently picked up a 2010 evo x, got the Tactrix Cable was trying to read the rom last night but it said unknown rom, so i decided to try it again tonight this is what i see
First selected 2006+ evo Can
Then after it did its thing, i see this
I dont see the ecu id (52680015 number)
And i stumble across a few post and i remember seeing it last night, did i mess up?
This is what i saw last night
I forgot what i did but i might have hit the use wizard to create a new definition
can someone help please?
Thanks
Ah10
Old Nov 20, 2009 | 10:38 PM
Ah10's Avatar
and i saved it and open back up, still dont see the ecu id =(
Old Nov 21, 2009 | 05:09 AM
SiC's Avatar
SiC
You need the 2010 xml file to read your ROM. Search for the 2010 model threads for the proper XML file.
Old Nov 21, 2009 | 07:53 AM
Ah10's Avatar
Thanks Sic,
dont i need to find the ecu id first then find the appropriate XML file like this?
Old Nov 21, 2009 | 03:38 PM
SiC's Avatar
SiC
Select use wizard and inherit the evo10base, just keep clicking thru next and you'll end up being able to see the ROMID.
Or if you have a hex editor, open up the ROM and check the 5002a address.
Old Nov 21, 2009 | 05:49 PM
Ah10's Avatar
Thank you very much!
This morning when i tried it again, i didnt see the opt again, how do i get that Wizard back up?
