P0068 maf/map tps correlation help
Old Nov 20, 2011 | 08:39 AM
jmorris1027's Avatar
I keep getting this fault code on my 2011 gsr. I have all the dtc disables active in ecu flash but there isn't one for this code. Is this something that will have to be fixed with the airflow check maps? My rom doesn't have these maps defined the way my 2008 gsr did. My romid is 56890007. Should I upgrade to a newer rom?
Old Nov 21, 2011 | 05:06 AM
I guess I should add, it only does it when I'm at wot, but it doesn't do it every time Im at wot. Sort of like an overboost condition I guess? The car is set to spike 26 psi.
Old Nov 21, 2011 | 05:37 AM
tephra's Avatar
are you sure its P0068?
what are your mods?
Old Nov 21, 2011 | 12:27 PM
Hks drop in. Perrin turbo inlet. Forge mbc. Megan cat back and test pipe. Ultimate racing uicp. Usually it will happen when I do a 2-3-4 run. it won't happen if I just do a 2nd or 3rd gear pull from 3000- like a dyno pull. I'm certain it's 0068 but I can double check in a couple minutes when I go out to my car.
Old Nov 21, 2011 | 07:50 PM
tephra's Avatar
well I couldn't find reference to P0068 in the 2008 manual, it might be in the 2010 FSM...
is that HKS filter an oiled type?
Old Nov 22, 2011 | 07:22 AM
No, its a dry filter. I re checked the faults and right now its showing no faults, so I guess it clears after a few key cycles. I'll get it to re-set the code and make sure its 0068.
http://helpforcars.net/obd_codes/p0068_mitsubishi.html
edit-googled the code and this is what came up.
Old Oct 19, 2012 | 10:22 AM
AIM WO4's Avatar
I got this code on my '12 (No mods) and 3,000 miles. Pulled over, shut down, re-started and the code disappeared. I didn't even have to clear it.
Old Nov 3, 2012 | 04:41 AM
|V8SRSLO's Avatar
I had this code last week,12 gsr , mods are, UICP,LICP, aem intake, exhaust. Turned out to be my maf sensor... After replacement and the small boost leak fix it was fine. I'd try swapping the maf and checking for leaks IMO. Worked for me
Old Nov 4, 2012 | 08:20 AM
Well I figured out I had my boost error correction values zeroed out in ecuflash so once I put them back I haven't had this code come back. This is with a grim speed 3port btw.
fayez-winner
Feb 20, 2017 02:04 PM
SiC
Jan 19, 2016 08:03 AM
thndrballl
Lancer Engine Management / Tuning Forums
Dec 31, 2015 01:15 PM
br3akrboi
Dec 6, 2015 11:40 AM
EvoCrazyyy
Dec 11, 2011 04:52 AM
