New SST real max torque.
Quote:
Originally Posted by FLK That's wrong, the SST is built by Getrag and it's model number is 6DCT470: Max. Torque Capacity 470 Nm (347 lbs/ft) Weight (dry) 99,5 kg Installation length 348 mm Input Shaft - Differential 197/207/215 mm Gear Spread Ratio 4,99 – 6,48 I believe only the clutch packs are supplied by Aisin. The exact torque limit in the Evo application is still unknown and shouldn't be too far from the OEM spec. Also, the MR has been released in the Japanese market for over 2 months now. The ASpec "delay" is mostly due to re-tuning because of different driving habits of the US population imo. " 347 fps, is that rite? Anyone know if its really correct? I am waiting for the MR, but if 347 is the real limit I may just get the GSR. I'm either getting a new evo or mazda 3 speed GT soon. Still can't decide, not enough info yet, still questions. This is from another thread and I think deserves a space all itself. I waited for a response but nothing. Can someone tell me if 347 is the real limit? I was waiting to get the MR but if thats true I'll just get the 5 speed. I don't see what use that new tranny would be holding no more than that. Thoughts everyone please. |
Originally Posted by Ridge Racer
(Post 5622838)
OEM Under-stated actual TQ. Limit!
IMO the stated torque limit is probaly 30% low for warranty purposes and general engineering conservative specifications. I bet we will find that the SST will survive at 450 Pound Feet of Torque when it is actually pushed by the tuners. It will most likely need more cooling by after market Transmission cooler packages and also some special clutch packages at this level of torque, and will satistfy 95% of the end user's need for speed out there when it comes right down to it.
Just My opinion. |
Originally Posted by jackygor
(Post 5622849)
You can't believe how happy people are already if 347 lb is the real SST's torque limit. Most SST potential buyers are happy with 300 wheel torque! Oh, and get 5 speed if you want a 500 HP Evo X...
If vishnas already got 400 and 400 out of just a mild tune then I wouldn't even use that 1k set up with the SST. Not at 347 max torque. To the other guy, you may be right but I think they probably only left 10 percent, if thats true you wouldn't be able to do much more than an cat back & k&n to it. I Just want to make sure I get a reliable tranny, thanks guys. |
(Post 5623784)
Well if thats true then most people don't plan on upgrading thier cars, I mean 300 is nothing. At 300 real max it wouldn't even hold up under heavy use for long as a stock vehicle.
If vishnas already got 400 and 400 out of just a mild tune then I wouldn't even use that 1k set up with the SST. Not at 347 max torque. To the other guy, you may be right but I think they probably only left 10 percent, if thats true you wouldn't be able to do much more than an cat back & k&n to it. I Just want to make sure I get a reliable tranny, thanks guys. But, anyway, that Getrag is not the same as the SST. Compare the pics and you will see the differences. And there's no way they only left a 13% safety margin. AMS figures their bolt-ons increased power on their test SST by 50-60 hp. Seems likely they also increased torque more than 13%. As far as what the SST will take in terms of increased output, I like the 30% figure. But not on top of the Getrag figure, which is of limited value since it's not even the same tranny. Instead I think that's a reasonable safety margin over the stock torque rating before the SST's TCM throws the engine into limp mode. |
The million dollar question is simply, what can the SST handle in REAL wtq?
And no-one will know until someone tries it and breaks it. |
I think we should have a prize for the tuning company that can prove the torque limit of the SST ---- with a criteria of no less than 3 SST breakages!
I'll donate an itunes gift card! |
^I'll donate an old pair of boxers!
ill donate a Wal-Mart gift card^^^
Originally Posted by Tsurugi-san
(Post 5626218)
Well, I heard a rumor that says all donations should be sent to my PayPal, but then what do I know....
Someone on here I won't name unless he sais its ok, told me mitsubishi figures it for 400 to 450 before problems start occuring. This is from a reliable source btw. So looks like I was wrong about the 10 percent. He also said that nobody really knows how much it will hold yet though. Humn, if its the 450 I might be able to love it till tranny upgrades become available. Thanks for the input everyone. I would like to see one break too. I imagine it will happen sometime soon.
We won't know until shops give it a try..............
(Post 5627270)
Someone on here I won't name unless he sais its ok told me mitsubishi figures it for 400 to 450 before problems start occuring. This is from a reliable source btw.
