Won't shift 3rd,5th | P2440 Code?
I have not had any SST issues with the car. Today on the way to lunch the car would not shift into 3rd/5th only R/1/4/6. I scanned the SST and it showed P2440. I can not find any reference to this code. After this everything is fine.
Thoughts? |
bump
trans codes go from p0600--->p0899 what did you scan it with ???
Originally Posted by todd6027
(Post 11334024)
I am new to this but it looks like there are higher digit SST codes: P2718: Clutch/shift pressure solenoid 1 system (Open circuit) P2719: Clutch/shift pressure solenoid 1 system (Overcurrent) P2720: Clutch/shift pressure solenoid 1 system (Short to ground) P2721: Clutch/shift pressure solenoid 1 system (Short to power supply) P2727: Clutch/shift pressure solenoid 2 system (Open circuit) P2728: Clutch/shift pressure solenoid 2 system (Overcurrent) P2729: Clutch/shift pressure solenoid 2 system (Short to ground) P2730: Clutch/shift pressure solenoid 2 system (Short to power supply) P2733: Clutch/shift switching solenoid 1, spool stuck P2736: Clutch/shift switching solenoid 1 system (Open circuit) P2738: Clutch/shift switching solenoid 1 system (Short to ground) P2739: Clutch/shift switching solenoid 1 system (Short to power supply) P2741: Fluid temperature sensor system (Gradient error) P2742: Fluid temperature sensor system (Output low range out) P2743: Fluid temperature sensor system (Output high range out) P2766: Input shaft 2 (even number gear axle) speed sensor system (Poor performance) P2809: Clutch/shift switching solenoid 2, spool stuck P2812: Clutch/shift switching solenoid 2 system (Open circuit) P2814: Clutch/shift switching solenoid 2 system (Short to ground) P2815: Clutch/shift switching solenoid 2 system (Short to power supply) |
il see if i can get hold of a wsm in a few mins {thumbup}
(Post 11334122)
| All times are GMT -7. The time now is 07:40 PM. |
