evo_x mr |
Apr 2, 2016 07:51 PM |
manual gate or no?
I tried doing a search but did not find any results. I was driving in super sport mode and paddle shifting but did not move the shifter to the manual gate. when I start from a stop it is in D1 and then I paddle shift accordingly which switches the box to a manual mode. when I come to a light or stop, the gears down shift on there own and it return to D1 until you start all over again. all was fine until I did a full throttle run which i mentioned starts in D1 until I manually shift it. under full throttle, the transmission shifted from 1st to 3rd gear. I panicked and got off the gas. I tried it again and the same crap happened. 1st-3rd gear. I tried one last time with the shifter in the manual gate and bingo! the transmission shifted flawlessly 1,2,3,4,5. did that once more and no skipping gears. my question is should I always have the shifter in the manual gate under full throttle accelerations? I know i definitely wont be doing that again. any input would be appreciated. forgot to mention that the evo is a stock 2015 with the exception of a cat back and only has 600 miles.
