Fluids
Old Nov 2, 2007 | 02:09 PM
  #31
RussellM's Avatar
Plat Vendor
www.mitsubishiparts.net
Plug the part numbers into the upper left 'search' box and then it will throw it in the cart. Then you can 'add' to the cart other numbers you want.
Be sure to use that free ground shipping code in my signature if you order.
Old Nov 4, 2007 | 06:28 PM
  #32
supeazn's Avatar
thanks ! but the free shipping code isn't working. I used both my email and urs and still didn't work ?
Old Nov 6, 2007 | 08:46 AM
  #33
RussellM's Avatar
Plat Vendor
Strange. Im not sure what the problem is with the codes. Just be sure to put 'evom' on the order and Ill adjust it.
Old Nov 6, 2007 | 08:48 PM
  #34
supeazn's Avatar
k i'll do that.. but where in the comments box ?
Old Nov 7, 2007 | 09:28 AM
  #35
RussellM's Avatar
Plat Vendor
When you are placing the order there is a 'shipping comment' section at the end of the order and you can put it there. Also, there is a question section on there that ask you how you found out, future changes, etc etc...most people put evom there.
Old Nov 19, 2007 | 01:32 PM
  #36
VtexGt3's Avatar
question guys, i went to the parts department and they gave me for the tranny... a part number MZ313501 ..... it came out of a 5 gallon drum and it said on it diaqueen multi gear oil... and under description it says M/T Lube and was listed at 12.98$ a quart.... does that sound right? Or was the guy high.. he gave me everything else correctly... so.. .... any thoughts?
Old Nov 19, 2007 | 01:38 PM
  #37
TTP Engineering's Avatar
Sounds like the proper 5sp fluid.
6sp Super Multi Gear oil is in a 4L container and $86-91 retail.
Old Nov 19, 2007 | 03:32 PM
  #38
RussellM's Avatar
Plat Vendor
Sounds right. Some dealers dont keep a large amount of 'gallons' on hand...instead they get the bigger containers for their shops to use. We have the larger containers too, but I dont advertise them...not sure how I would ship it and it be worth it.
Old Nov 19, 2007 | 03:47 PM
  #39
VtexGt3's Avatar
awesome thanks alot guys
Old Dec 15, 2007 | 09:06 PM
  #40
RussellM's Avatar
Plat Vendor
FYI - Im doing free ground shipping through this month on all Diaqueen Fluids.
Old Feb 28, 2008 | 10:18 AM
  #41
lords3t's Avatar
Bumping this thread cause I feel like it RussellM's a good vender. Fast shipping, good communication, and the fluids on his site work perfectly in my IX MR (6.speed).
Old Feb 28, 2008 | 10:22 AM
  #42
RussellM's Avatar
Plat Vendor
Wow!
I really appreciate that.
As a side note Im selling the two Diaqueen fluids at $1 over cost...so stock up if you plan on changing your fluids frequently.
Old Mar 13, 2008 | 08:37 AM
  #43
sl0ev0's Avatar
this thread officially confused the f outta me. i was going to go with oem fluids for my trans, but since not even mitsu really knows whats supposed to go in the 5speed or 6speed, im going to try out redline mt90.
if anyone can verify using the 6speed oil in the 5speed and having no problems, that would be great. or if anyone knows where to get the 5speed stuff.
Old Mar 27, 2008 | 02:38 PM
  #44
lemmonhead's Avatar
the dealership just ordered in transmission fluid # MZ313376 for me,
Old Mar 27, 2008 | 02:56 PM
  #45
RussellM's Avatar
Plat Vendor
Ordered it? They didnt have it?
What was the point of this post?
