Looking for Fuel? NEW Direct Fit 320lph E85 Compatible AEM Fuel Pumps!
Need More Power? AEM Has the Answer!
For as long as people have modded cars, the quest for more power has been limited by the lack of proper fueling. AEM has been a leader in fueling innovations for many years, and they’re continuing to push the quantum quest for power with the NEW AEM 50-1220 and AEM 50-1215 fuel pump kits.
Available in two premium packages (on with mounting hangers and one without hangers) you can get the best fueling solution for your needs. With common applications such as Evo 8/9 and Evo X and 1G/2G DSM’s, the AEM E85 320LPH fuel pumps are available for some of the most popular vehicles on the street today!
Designed for high performance turbocharged/supercharged engines, each AEM E85 fuel pump is individually tested to hold power at well over 1,000hp. Flowing 320lph at 43PSI is a baseline, and more than enough fuel for most performance applications. Built around a slim, compact body, the AEM 50-1215 and AEM 50-1220 pumps are fully modular and work well within custom applications and has been proven to work well within the low lubricity environment found in ethanol fuel up to E100 and methanol fuels up to M100
Features of the AEM Direct-Fit 320lph E85-compatible High Flow In-Tank Fuel Pump:
Contact MAPerformance today with all of your performance oriented questions. We’re happy to help get you lined up with the best aftermarket parts, all at the lowest possible prices. We have industry best customer service and the fastest shipping in the industry, so check us out today and let us show you why we’re the absolute best in aftermarket performance industry.
- Tested and compatible with ethanol fuels up to E100, methanol fuels up to M100 and all types of gasoline
- Designed for high output naturally aspirated and forced induction EFI vehicles
- Each pump is tested to flow 320 lph @ 43 PSI
- Compact body (39mm diameter x 65mm length)
- Kit includes fuel pump, wiring harness, pre filter, fuel hose and stainless-steel clamps
EVOn9ne
Jun 28, 2013 12:05 AM
maperformance
Apr 30, 2013 04:02 PM
AWD Motorsports
Aug 8, 2011 11:31 PM
AWD Motorsports
AWD Motorsports - Florida
Feb 10, 2011 04:45 AM
