MAPerformance Fall Clearance Closeout!
The end of the busy season is here at MAPerformance, and we're getting ready to liquidate all clearance parts from our inventory. Dont disregard these items, some of them are popular aftermarket bolt-ons and they will not last long!
Take a look at just a few of these amazing items being offered during the MAPerformance Clearance Closeout, and click the banner above to see everything!
EXEDY flywheels combine low weight, low inertia and high thermal capacity. They are designed for lightly tuned racing cars for drag racing, autocross and rally events, as well as street usage. They are made from solid one-piece billet chromoly steel or chromoly steel forgings. They are specifically designed to reduce weight and inertia for better engine response. Most incorporate special design features to enhance the airflow which improves the cooling of the clutch.
The Cosworth Thermal Guard Composite Intake Gasket is designed to aid in the reduction of inlet air temperature by isolating the intake manifold from the heat generated by the engine's cylinder head. By reducing the temperature of the inlet manifold the temperature of the intake air charge is also reduced. The density of cooler air is greater than that of warm air. A denser intake air charge contains more oxygen which results in the potential for increased power and torque.
Delete your factory EGR with The Torque Solutions Billet EGR Block off plate. Available with countersunk recessed screws for a nice clean look, this kit will install in under 15 minutes. Made out of lightweight 6061-T6 billet aluminum, you dont have to worry about warping to fatigue. Includes a Life Time Warranty and Made right here in the USA!
Add our optional heat shield package to protect your valve cover from the heat of your new tubular manifold. Please note this is not intended as a stand alone solution for 2010+ models with plastic valve covers, it is likely you will need to go to a metal valve cover to utilize this kit without having to worry about your valve cover!
At MAPerformance, we dont just offer the best pricing in the industry, we also bring FREE Shipping for orders over $199 and top notch customer service. If you have any issues with the parts you order, contact us and we'll do our best to make it right. We aim to make your aftermarket part purchases as hassle free and painless as possible! We're happy to assist with any installation issues you're having, and help guide you in the right direction to get you back on the street!
