GSR Lancer interchangable/replacement LCA's
cm5a, LCA, suspension, lancer awdld be swapped for the stock ones of the1996 lancer cm5a model, that would allow me to use suspension that has "fork type" bottoms instead of the "knuckle bush type of the factory suspension?
Pretty much so that I can fitt something like this http://www.google.co.nz/search?q=tei...kQXc_IGYBg#i=4 Instead of this http://www.google.co.nz/search?q=tei...MMmlkQXc_IGYBg ...or atleast any LCA that would match the dimensions of the stock ones. Any advice or tips would be appreciated. |
Hi sir,
I will check into this & see. |
| All times are GMT -7. The time now is 03:35 PM. |
