need help with coilover setup please
8/10 with stock swaybars is the Vishnu/Gerrard spring rate ratio so that's probably not causing snap oversteer. Assuming the toe is correct (0 in front and bit of toe-in at back) then that is also fine. You ride height is close also. Therefore I'd assume something is abnormal. Perhaps the rear dampers are set too stiff? Has the car even been in an accident?
part of the reason I am gathering recommendations is that I am going in for a re-alignment.
I am thinking more rear camber, at least -1.8 to -2 if I can get it.
what is a good rear toe setting?
Also, what about my ride height? Am I way off? I can set that before going back for the alingment.
Your ride height w/ the higher front is giving the rear more grip--which is what you're looking for.
I think the higher rear spring rate bias is definitely causing the behavior--since you're not used to that. Tuning the dampers as mentioned before by softening the rear (which you've already done by running it softer in the rear) will help.
Ultimately you may need to get the rates equalized or reversed to suit your driving style. I know from experience I prefer a nuetral car, not one that's too twitchy. Now if I were into rallying......
It sounds like you may have a little toe out in the back, but it could be a few other things. Your rear camber is OKAY.
Also, you may want to try either lowering the front of the car or raising the rear. Just a smidge. I'd certainly check your toe settings first before messing with this.
Did you post your tire pressures? Glanced through and couldn't find them?
- Andrew
- Andrew
Tire pressures were initially (cool) 32f and 36r. this was not good.
Over the course of a couple sessions I lowered the rear down to 30 (along with softening up the rear dampers), and the car was more under control. I'd left the front at 32.
where is it apppropriate to measure the ride height?
If you were at 30 hot in the rear, that might be part of your problem. Too low IMO for street tires.
There will be variations when you measure to a body panel like a fender, should be more accurate and repeatable measuring to the frame instead. It should also make it easier to determine if you have the car raked.
Thanks mad 8.
I think I'll leave my ride heigt as is, and work with the alignment, damping and tire pressures to get where I want.
I need to search for recommended alignment specs. some have already been proposed in this thread, mostly toe. I am leary about much toe because is kills tires so fast and I use my street tires for everything.
Thanks mad 8.
By looking at all your information, the rear spring rate would be the main reason why your car is oversteering. You are allowing more rear weight transfer than front. Of course alignment and driving style will affect too but if you have driven on the track with stock suspension and BC coilover and oversteer is quite significant then primarily it must be rear spring rate too high.
so, I don't mind oversteer. I mind un-warned snap oversteer into a spin.
since the spring rate ratio I have seems to be the most highly recommended by performance enthusiasts, I am trying to gather input on how to get the breakaway more controlled and gradual.
from reading all the posts, I think I have found an answer: adjust my toe settings, and then fine tune with damping and tire pressures. I'll report back ni October sometime how it turns out.
you know a small part of your problem may be your tires. I think the stock tires do not like modified suspensions at all. especially before they are hot or when they are hot*. pressure too of course.
last time I had any problem with the quick other way was on the stock tires.
I would definitely give Robispec a call and see when next he will be in your area and have him look over the car. Not only can it take you long to figure out the issue but it can be dangerous at the limit, plus he can advise you what will work.
Calling him is no obligation. PM me if you want his number.
Duncan
Duncan
