Let's see YOUR track Evo
#1786
Yes it's the Evo VI oil cooler vent. Can't give definitive data on it because when I added it I also added the Varis oil cooler duct and last track season's outside temps were pretty low (sub 80F). So while the oil temps stayed a bit lower than they had been in previous seasons, I can't say that it lowered the temps by <x> solely due to that, and not due to the combination of the above factors.
#1787
#1792
Last year, the car was in TTB, and my weight to power was 10.6 (just shy of the 10.5 limit). This year, the TT4 rules are a little different. The weight to power ratio is is limited to 12:1. However, that number is deceiving because the class calculator applies modification factors to your actual weight to power ratio based on mods and car attributes. For example, i get +0.2 for having a 4 door, +.07 for running 245 size tires (even though 245 hoosiers are really 265/275's) and -0.5 for being AWD etc. My peak weight/hp ratio is 10.8, but with all the modification factors, it comes to 12.009 (just 0.009 above the allowed minimum value of 12.0 lbs/hp). Last year, the car had a slightly better weight/hp ratio, but was on NT01's and stock suspension. This year, the car is on ohlins, has hoosiers and Aero and has dropped about 75 lbs. During testing at the Glen last week, I turned a 2:08.5 lap not even pushing the car, still just trying to find the limits of the tires. My best time last year at the same track was a 2:13.xx
https://www.youtube.com/watch?v=7LrAJmzaS2E
#1793
what was that grey thing that went past you and the alpha ??
#1797
How much research have you done on canards? From what I've been able to gather reading and talking with some guys, it seems like those might be a little low and taking away from your splitter downforce. Of course I have very little to go on and curious how you came to the solution you have.
