Let's see YOUR track Evo
Old May 30, 2018, 09:20 PM
  #1816
huzzle101's Avatar
Subscribed
Old May 31, 2018, 01:15 AM
  #1817
cficare68's Avatar
Engine:
Aluminum Rod 2.4
- JE Pistons (8.5:1)
- BME Rods
- OEM 100mm Crank
- Kiggly Springs and Retainers
- Supertech Valves
- Bronze Valve Guides
- Stubby balance shaft
- Straight cut oil pump gears
- Kelford 276 High Lift cams
- ITM Revised Lifters
- ARP 625+ Head Studs
- AEM Tru Time Cam Gears
- Shaved Valve Cover with throttle cable bolt hole deleted power coated wrinkle black
- Clear cam gear cover
- Carbon Creations Carbon Fiber Spark Plug Cover
Forced Induction
- STM Forward Facing Hot Parts Kits
- STM LICP
- JM Fab UICP
- JM Fab Drag Intake Manifold
- ETS 4" FMIC
- BorgWarner S257 Sx-e turbo (t3 .82 ar turbine housing)
- English Racing Boost Activated Cutout
- Buschur Racing Catback
- Boomba Throttle Body
Fuel System:
- FIC 2150cc Injectors
- Boomba Racing Fuel Rail
- 8an feed line
- 6an return line
- Jegs Hi-Flow 8an fuel filter
- Customer walbro 450 lph double pumper
- Fuel Lab fuel pressure regulator
Cooling:
- Mishimoto Half Sized Radiator
- OEM cooling fan
- Mishimoto Race Thermostat
- Carbon Creations Carbon Fiber Radiator Shroud
- STM 12an upper thermostat housing
- 12an upper radiator hose
- Gates lower radiator hose
- JM Fab Radiator Brackets
Electronics:
- AEM EMS V1 ECU
- AEM 50 psi boost gauge
- AEM oil pressure gauge
- AEM boost solenoid
- AEM Wideband
- JD Customs Coil on Plug Non CDI ignition system
- Fuel pumps hard wired
- Hella Horns
- Battery Relocation Kit
Drivetrain:
- Buschwacker Ultimate Ratio transmission w/ Evo 8 jdm 5th gear and 4.11 final drive
- Exedy Triple Disc Clutch
- Qualfe LSD Differential
- Solid Driveshaft bushings
- Solid Shifter bushings
- Polyurethane Diff Bushings
- Plate swapped evo 9 rear diff
Suspension:
- Cusco Strut bar
- Whitelines front anti sway bar
- Whitelines rear anti roll bar
- Megan Racing Street Coilovers
- Whitelines Power steering rack bushings
- DD Rear Lower Control Arms
Wheels/Tires/Brakes:
- Cosmis Racing MR II (Bronze 17x9 + 10 offset)
- 10mm spacer (front only)
- 255/40r17 Bridgestone RE-11A Tires
- Stock Brembo Calipers
- Drilled and Slotted Rotors
- Ceramic Pads
- Stoptech Stainless Steel Front Brakes
- STM Hydraulic Staging Brake Kit
- ABS Deleted
Interior:
- SSL Seats
- SSL Door Cards
- Evo 9 Steering wheel
- Pioneer Dual Din DVD Player
- HVAC relocation kit
- AMS Carbon Fiber Shift Knob
- Infinity Rear Speaker
- Pioneer Front Speakers
- Dynamat
- Steering Column Guage Pods
- Ash Tray Gauge Pod
- Carbon Fiber Wrapped Trim Pieces
Exterior:
- Carbon Fiber Style Vortex Generator
- APR Carbon Fiber Splitter
- Rexpeed Carbon Fiber Sideskirt Extensions
- Rexpeed Carbon Fiber Bump Extensions
- Rexpeed Carbon Fiber Trunk Lip
- Carbon Fiber Rear sideskirt end caps
- Seibon OEM Style Carbon Fiber Trunk
- Seibon OEM Stylr Carbon Fiber Hood
- DEPO JDM Evo 9 tail lights
- Painted Black housing headlight housings
- Polyurethane Do-Luck Style front lip
- Carbon Fiber Air Ducts
- Custom Front bumper block off plates
- Carbon Fiber Front Mitsubishi Emblem
- Stubby Antenna
- JDM Fender Signals
- Carbon Fiber Wrap Rear Reflectors
- Window Rain Guards
- EvoDan Fender Mod
Future plans:
- Carbon Creations Carbon Fiber Front Fenders
- Custom sunroof delete
- NRG Carbon fiber roof overlay
- JM Fab Fuel Rail
- JM Fab Billet Oil Cap
- JDM Rear Bumper
- Vibrant Rear Muffler
- Wrap the non carbon parts a different color (haven't decided on a color)
Old May 31, 2018, 01:29 PM
  #1818
Dallas J's Avatar
That things a monster truck, why so tall?
Old May 31, 2018, 04:43 PM
  #1819
cficare68's Avatar
Crap roads, a curb to get into my driveway, and around 1k in ground effects that i would prefer not to destory and wheels with a massive offset that rub on rolled and pulled quarter panels when launching if its any lower. Take your pick. Car also spent a month and a half on jackstands on all four corners as well. So the suspension needs to resettle.
Old Jul 1, 2018, 07:09 PM
  #1820
L888Apex's Avatar
Waoooo, can’t wait to post mine here after almost 6 years of being out of the game.
Tentative mod list below upon completion:
engine
-2.0LR
-port flow designs built head
-GSC S2 cams
-GSC valvetrain
-ARP L19 headstuds
-stock 9 turbo Mil.Spec ported (until I get used to the car again)
-Curt Brown extreme ported intake manifold
-Curt Brown extreme ported FP cast manifold
-Mil.Spec ported 65mm TB
-Mil.Spec ported invidia o2 housing
-Moroso oil pan
-Injectors TBD
Suspension/brakes
-JRZ RS Pro’s
-Perrin PSRS
-Whiteline bumpsteer kit
-Robispec 26mm sway bar
-AP Racing 4 pot front brake kit
Drivetrain
-KT Motoring built 5 speed
-Sheptrans t-case
-Robispec rear diff
-ACT XTSD
Old Jul 1, 2018, 07:47 PM
  #1821
Received 1,384 Likes on 1,317 Posts
Ben
What is your plan for the EvO. Will you be tracking it hard like years ago, or are you considering it just a hard core streeter?
Maybe both?
For me, I was working the Fontana track hard (at least i thought so) but the cost, risk factors & the overall condition of the car made me move it off the track. Been cleaning mine up & enjoying the increasing value of the EvO (could sell it for what I paid for it 10 years ago
Just had RRE do my 60K service & had the S2's installed w/the FP HTA71 (runs good & idles sweet)
Joe
Old Jul 1, 2018, 08:44 PM
  #1822
L888Apex's Avatar
Ben
Maybe both?
Joe
what’s up joe! I’ll be tracking but not quite as often as I used to because of work. Maybe 6 track days or so per year and some light street duty of 5-10k miles per year. I’m way upside down compared to what I’ve put into the evo so resale value isn’t even taken into consideration haha how are you liking the s2’s?
Old Jul 2, 2018, 05:02 AM
  #1823
The S2's rumble for sure. Its just a little softer on the bottom & requires just a bit more rev & clutch slip in 1st. My tune has my setup limited to 7500 RPM but, for sure, there is more power up top
The idle on the S2's is addicting
Old Jul 3, 2018, 08:48 PM
  #1824
codgi's Avatar
You probably want to re-think that Moroso pan. Since you've been away we realized it's really good for drag Gs but not lateral Gs. There are other options out now that you should look into like the RaceFab.
I didn't know Mil.spec was porting o2 housings now. I couldn't find it on their site is this a local hook up or something?
Old Jul 4, 2018, 03:35 AM
  #1825
L888Apex's Avatar
local thing, but that was about 6-7 years ago lol
codgi (Jul 4, 2018)
Old Oct 21, 2018, 08:14 AM
  #1826
CN18's Avatar
Some action shots from the Nürburgring Nordschleife in March 2018
Old Oct 22, 2018, 08:26 PM
  #1827
codgi's Avatar
^^ nice
Old Dec 28, 2018, 08:18 AM
  #1828
sumopower87's Avatar
Ping! Subscribed! 😎
Old Jan 16, 2019, 10:16 PM
  #1829
xBoostx's Avatar
It felt weird being in a car show. But i thought I'd give it a shot LOL
Old Feb 24, 2019, 06:24 PM
  #1830
Bee-Raddd's Avatar
Quick Reply: Let's see YOUR track Evo
