Are replacement caliper pistons for OEM Brembo Evo 8/9 brakes available?
Did anyone actually find a place that sell the pistons for brembo calipers on the evo's 7,8,9.
Im badly stuck for a 46mm piston for the front caliper.new or second hand would do at this stage
Interestingly, Girodisc has had exactly zero requests for replacement pistons, until I called... and then within 24 hours, a guy in FINLAND wanted a set, and emailed pictures of OEM pistons evidencing virtually the same heat damage as mine.
By the way, the Brembo pistons that HRPworld.com sells WILL NOT work on OEM Brembo Evo calipers:
http://www.hrpworld.com/googlebase.c...action=product
- are for Brembo race calipers - which are deeper b/c the pads they use are about 20mm thick, and need to be able to accommodate a greater range of motion as they wear - instead of 15mm for street-based applications. Therefore, those pistons wouldn't work on the calipers from an Evo, which are only 29mm deep.
If there is enough interest...there could be a REbuild/replacement kit-UPGRADE for the Brembos, with better internal components. Right now it is in the planning stage, but if there are enough of U who want it..it could be in production fast as all the details are done. Pete
I'm on the fence if to rebuild my blackbos as well... $100 per caliper (http://www.girodisc.com/catalog/prod...840fef01b96dee) + the work, or just pick up some used clear coat pealing pinkos for about the same total price...
The only thing you can really improve on are the pistons...that is really the only place where you can make any change to the Brembos and get a significant improvement in the performance of those calipers. Pete
Maybe I missed it... but just curious as to what a redesigned piston would improve? I recall a thread showing some coating coming off, but other than than, my knowledge is too little to even guess at what else one would improve in a caliper piston. The material maybe for less heat transfer?
Getting away from the aluminum pistons should be the best way to help control the temp transfer and the properties of the actual piston when it is heated up. The "transfer" coatings (Swain and others) is an interesting option and seems to work very well. But for this idea, I think a different metal for the piston itself is a great starting point. Pete
