Kidloco51's IX MR track car build thread.
#152
Make sure you get a good feed source for the box, the headlight should be OK, but you will need at least 3" diameter feeding it.
My box isn't crazy sealed it's pretty much the same as yours and I use a 3" tube from the lower bumper inlet. I wanted to do a test where I blocked of the brake ducts, which share the same inlet on the drivers side. Well when I taped off the inlet The car would not run under any throttle, it would just sputter and fall on it's face. I thought that because I didn't really seal it off the airbox could scavenge air from the seams and still get what it needed. That was wrong the box will need a good supply inlet that can support the horsepowers you will make.
every car i had , it had an air feeding hose, even a stock box
just "behind" the license plate that silver inlet is the air feeding hose.
(bad habit )
#154
#156
The air intake box looks good. If you don't have room to snake a hose from behind the bumper area to for an air feed, another option is to have your friend redesign the top cover to accept the stock intake snorkle. When I designed my intake box I kept the stock snorkle and also added a hose from the front bumper to the air filter. Here are a couple of links to pictures:
https://www.evolutionm.net/forums/9559983-post4.html
https://www.evolutionm.net/forums/9561227-post13.html
Here is a link to the NACA Duct that I mounted behind the front bumper air opening to attach the hose to:
https://www.pegasusautoracing.com/pr...p?Product=3628
If you do decide to look into modifying the headlight for a duct send me a PM and I will give you a phone number for a guy that has done it before and might be willing to do it again.
Dan (drb)
Dan (drb)
#159
What FP are you running now? You should be good up to about 430-440whp (Mustang Dyno) w/ a single Walbro, but anything more and you'll be running out. Good to see you making progress! I just took a few steps back last week at Laguna Seca. Blew up my 4 month old 2.3 stroker.
