Kidloco51's IX MR track car build thread.
Old Jan 1, 2017, 03:11 AM
  #676
kaj
kaj's Avatar
Originally Posted by mouseIX
car looks amazing!
I plan on finally getting around to making a set for 2 cars local to me. Sorry to highjack.
https://www.evolutionm.net/forums/motor-sports/695091-billet-shifter-risers.html
I'm making some too. 1" x 3" aluminum stock, Female threads on each end with a set screw to make a male side. Then slap everything together. Should be dirt cheap.
Old Jan 1, 2017, 08:27 AM
  #677
Kidloco51's Avatar
Pretty much the same. I machined down the ends to fit in the shifter base.
Old Jan 1, 2017, 11:46 AM
  #678
kaj
kaj's Avatar
Nice! I can't wait.
Old Jan 1, 2017, 02:41 PM
  #679
211Ratsbud's Avatar
i was able to do it for dirt cheap like this
Old Jan 1, 2017, 03:56 PM
  #680
kaj
kaj's Avatar
Details?
Old Jan 1, 2017, 05:12 PM
  #681
211Ratsbud's Avatar
Whatever size the base bolts are, 10 or 12mm? I used slotted roll pins in whatever rise I wanted , sandwiched a washer on each side of the plastic base, sans rubber bushings, and a washer at the base of the stand. Possibly 5$ worth of hardware and zero fab. I raised it and cut the shifter hole bigger in the console, and made a boot to cover it.
extremely rigid and zero flex in the riser assembly. I also modified the leverage ratio on the side to side gate selector, reducing lateral distance between 1-3-5 etc. Longitude throw, I lengthened the bottom of a torque solutions shift lever.
Old Jan 1, 2017, 09:11 PM
  #682
honda-guy's Avatar
nice progress
Kidloco51 (Jan 2, 2017)
Old Jan 2, 2017, 02:40 AM
  #683
kaj
kaj's Avatar
Yup. I'm doing this today!
Old Jan 2, 2017, 06:22 AM
  #684
Kidloco51's Avatar
Got the Ecu mounted to the floor. Wiring is pretty much done just need to clean up a little and zip tie some stuff.
Picked up this Nagisa tow hook for $25 last year and finally installed, now I look like all the cool kid evos.
I decided to loose the big muffler in the back for weight and aero. Made a cheap little pipe to replace with.
Old Jan 2, 2017, 01:06 PM
  #685
V.8MR's Avatar
I wana do this also. Just straight pipe from axle back.
Old Jan 2, 2017, 02:18 PM
  #686
Balrok's Avatar
Make em so you can also put a muffler/resonator either there or in the test pipe area for those tracks that DO have noise restrictions (of which there seem to be more and more these days )
Old Jan 2, 2017, 03:16 PM
  #687
kaj
kaj's Avatar
I want one of those tow hooks so I can quit replacing straps. But when a strap is $30 and that tow hook is $150...
LOL
Old Jan 2, 2017, 05:28 PM
  #688
Kidloco51's Avatar
Whats nice is the original muffler is slip fit so it takes about 5 minutes to swap if needed
Old Jan 12, 2017, 03:18 PM
  #689
Kidloco51's Avatar
Picked up a set of used 18x11 +18 TE's. 295's going on but wanna fit 315's.
Size:  195.3 KBName:  IMG_3065_zpswdinkrwy.jpg
Old Jan 12, 2017, 04:15 PM
  #690
RJones's Avatar
Step up your game! Gotta get 12s and 335s!
Just curious... are you running a spacer up front in that pic? I'm surprised at how sunken the 11s look w/ those over fenders. I was considering getting them to fit my 12s.
Quick Reply: Kidloco51's IX MR track car build thread.
