Tow Rigs, What do you have/use?
EVO196 (Jun 6, 2019)
#933
How are you guys strapping down the car from the rear? I bought 4 of these t-hooks, but on the drivers side rear the frame holes are crowded by the brake lines. I can use axle straps around the rear lower arms, but there is no way to cross them due to the exhaust on the passenger side hanging down too low. So, my plan is to use the t-hooks in the front crossed and the axle straps in the rear around the lower control arms straight back to the tie down points. Unless there is a way to use the 3rd and 4th t-hooks with chain loops that I bought for the rear, they will be up for sale...
#934
I've never had an issue not crossing straps. I just wrap the strap around the lower control arm in board of the shock. The d-rings on my trailer are located so that the straps do have a slight angle. With 4 straps on the car, even if they are perfectly straight, it's not going to move side-to-side if they are all properly tight as ****.
#935
