2013 SCCA PAX Changes
Old Dec 12, 2012, 12:57 AM
  #31
griceiv's Avatar
Originally Posted by Meathooker
how many, if any, of you are looking at going SM since the ASP/SM pax are virtually identical?
*raises hand*
although we'll probably do it with an asp legal car.
Old Dec 12, 2012, 04:14 AM
  #32
psushoe's Avatar
Go away, we don't want your kind (fast enough to beat SM in SP trim) here
Old Dec 12, 2012, 02:58 PM
  #33
flmjr's Avatar
I thought that maybe Marshall was intending to turn Christine loose in SM.
Frank
Old Dec 12, 2012, 03:58 PM
  #34
Meathooker's Avatar
Originally Posted by griceiv
*raises hand*
nice!
i was looking at the $$$ in available mods and its a big jump to get fully prepped or even 95%.
what are your guys's thoughts on the best first mod or 2 going from ASP to SM?
cams, turbo, PSRS?
Old Dec 12, 2012, 07:38 PM
  #35
doc29's Avatar
Turbo...injectors...fuel pump....as a start....then cams..sd tune...finally stretched gears, built motor, 600 whp 500+ wtq sounds about rite....some 315 at each coner wouldnt hurt...and pray it holds together...lol:-)
Old Dec 13, 2012, 12:36 AM
  #36
griceiv's Avatar
nice!
cams, turbo, PSRS?
less weight. oh and new class magnets.
power is very low on the priority list. the biggest weakness of an ASP evo is it's mid corner speed...or lack there of.
Old Dec 13, 2012, 07:47 AM
  #37
Meathooker's Avatar
should have mentioned that i race hillclimbs as well so i keep going to the power adders, but yes for purely autox light weight is the next step.
been reluctant to drop AC (for resale value) but i'm thinking getting that weight off of the front of the car is key.
Old Dec 13, 2012, 08:17 AM
  #38
RJones's Avatar
Honestly, I don't think you need more power between ASP and SM if you're running e85. I already shared my thoughts on that with you via pm though, lol.
Old Jan 23, 2013, 01:33 PM
  #39
DaWorstPlaya's Avatar
New Feb Fastrack out!
http://www.scca.com/about/?cid=44415
Seems like E85 may not be allowed in ST unless the car was designed to utilize it from the manufacturer.
Old Jan 23, 2013, 02:55 PM
  #40
Bassicfun's Avatar
2014... still legal for 2013.
Old Jan 25, 2013, 08:17 AM
  #41
Dallas J's Avatar
What weight are people getting down to in ASP?
In SM I'm sticking with 285s, 315s are just more car width to deal with. Though 275s if its possible to get into the 26xx range would be exciting though not sure thats possible within the rules.
Old Jan 25, 2013, 09:05 AM
  #42
griceiv's Avatar
Cy Lee said his car was ~2900, we're still trying to get there. I don't thnk 26xx is doable in SM without some drastic engine changes (like an aluminum block).
I would happily deal with the extra width of 315's if i could.
Old Jan 25, 2013, 11:47 AM
  #43
psushoe's Avatar
Agree and did
There is extra weight associated with some SM mods, too. Wider wheels and tires, big azz wing on the back, larger front splitter, and there's not a whole lot more that can be done to reduce weight. OEM hood is pretty light. Trunk could be done... By my calcs, I think my theoretical (money no object) min weight is around 2850 based on my last weigh in. Maybe a little less.
Old Jan 25, 2013, 02:13 PM
  #44
griceiv's Avatar
I think with a bit of effort 27xx is possible but certainly not cheap or easy.
Old Jan 25, 2013, 07:13 PM
  #45
Dallas J's Avatar
Ive done extensive research and considering Ive only taken into account larger items, I'm certain 27xx is possible. I know with a wing and splitter I can get into the low-mid 2800lb range for under $2000.
Quick Reply: 2013 SCCA PAX Changes
