Let's talk end links!
Old Apr 14, 2014 | 12:36 PM
  #46
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Now I'm worried about mine.
Old Apr 14, 2014 | 12:41 PM
  #47
heel2toe's Avatar
^I see you bought the Perrin for the rear. What did you end up doing for the front?
Old Apr 14, 2014 | 12:51 PM
  #48
charlie.tunah's Avatar
I can take some better pics of mine if you want more reference for lengths. Im not sure how the geometry of the tanabe bar differs from stock as far as endlink angles are concerned (or the ciro brackets), but it should give you an idea of what to expect.
Old Apr 14, 2014 | 12:55 PM
  #49
heel2toe's Avatar
If you don't mind that would be great, thank you!
Old Apr 14, 2014 | 02:36 PM
  #50
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I went Perrin all the way around.
No pics of the rear.
Old Apr 14, 2014 | 02:52 PM
  #51
^^^That's a HUGE difference in comparison to my angles. You have the non offset PSRS, right? Tanabe bar?
Old Apr 14, 2014 | 02:54 PM
  #52
golgo, do you have a pic from the front? Any spacer at the bar? Can you reach the 3rd hole?
Old Apr 14, 2014 | 02:58 PM
  #53
golgo13's Avatar
EvoM Community Team
Veteran: Navy
Correct. Yes, I have EGBeater's old bar.
No pics from the front at the moment. No spacer in the bar. Haven't tried reaching the third hole. This is my first time on this set-up so I'm easing into it on the Medium setting up front.
These are the only other pics I happen to have at the moment, some of them are test fitment with the ES bushings, which I've since sold:
Old Apr 14, 2014 | 03:01 PM
  #54
heel2toe's Avatar
Its cool that you two have the same exact bar as well as Cusco bracket as Im over here all alone with my stock drilled bar and CDR bracket.
I don't see how the PSRS would change the mounting point for the bracket that much. One thing that I noticed that's different from both of your pictures is that it appears that [Charlie's] LCA is angled lower than Golgo's which could be due to the fact that his knuckle isn't connected. I wonder if you were to connect the LCA to the knuckle and reinstall your strut without a spring and put it through an entire stroke if you would be able to shorten your end link and as such allow you to use smaller spacers?
Old Apr 14, 2014 | 04:14 PM
  #55
Im still waiting on my coilovers. I may end up putting the HDs and swifts on for clutch break in/cruise tuning, but Im probably not going to break them down unless I part them out afterwards. Definitely going to install suspension all around without springs and test it all out..hopefully soon.
LCA is flat in these pics. Looks like I may need a small spacer on the bracket and I think the sway side is good. But definitely cant make it to hole #3 without a lot more spacer.
Old Apr 14, 2014 | 04:16 PM
  #56
^^this is a 2" top bolt and a 1.5" bottom bolt fwiw. Looks like Im going to end up using the 2" hardware that I originally bought on the bottom
Old Apr 14, 2014 | 04:48 PM
  #57
heel2toe's Avatar
Thanks for the additional pictures. It looks like I am going to have to play around with different size bolts and spacers and see what fits best since I've got a funky slew of parts.
Just curious as I cant quite visualize this in my head. Looking at the bottom picture it appears that the cusco piece has 4 holes. Is the hole furthest to the right the stiffest setting?
Old Apr 14, 2014 | 04:54 PM
  #58
Terror Rising's Avatar
Tunah - from your pictures you definitely need more spacer on the bottom. I did a rough measurement on the stock links and it looks to be around 7/8" from the center of the sphere to the mating surface on the link. I just took a picture of mine in a similar position to Golgo's and ours match. I'm using a Whiteline caster bushing (0.5°).
Old Apr 14, 2014 | 04:55 PM
  #59
golgo13's Avatar
EvoM Community Team
Veteran: Navy
I don't have the instructions in front of me, but IIRC it's for a different platform.
In my pic you can see them labeled as H, M, S.
Old Apr 14, 2014 | 05:04 PM
  #60
+1. Just the 1st 3 holes are labelled as ct9a in the instructions.
