Strange RS3 tire wear...
Here is the picture of this strange wear that I was getting over the weekend event:
The left side is on outside and you can clearly see lot more heat effect to that side of the thread. Interesting part happens for the two section on the side of the middle ring that have those curvy impressions. As you can see the one on the right side shows more wear than the one on the left side which is closer to the section that got lots of use.
Anyone has any idea what would make it to create that kind of uneven wear?
Fedja
Fedja
My best guess would be from tire squirm cause the surface to sort of roll like ~ . I get odd wear kind of exactly opposite on the race tires with a ring around roughly where your outside flame is.
Also, and not quite apples to apples, when testing my ZII's they did some really funny things with lower pressures. Inside temps were really low and outside and mid would change equally with in the 30psi range. I tried lower based on roll but that just lost grip. Then I went up in pressure, got more grip and more roll. Also the temperature across started to get closer to linear when tested on our skidpad.
Those are the pressures I start each run with. I would start with them and keep them at that level through the event.
I just don't understand were that notion of EVOs being tight and need to rotate them more is coming from. I have yet to experience understeer with EVO and rear is the only part that needs to be taken care for! That is why I had to run 34 psi in rear vs. 41 for front when running 285 Hoosiers...
Fedja
Just autoX.
Fedja
Fedja
Fedja
Steady state seem to be fine for me at this time!
Fedja
What I mean is that rear end is the one that is getting away and moving more than is needed. When you are in the slalom for example you still have to be careful and keep the rear end inline otherwise it start to get out too much and you ended up loosing lots of time. Another place is when you have decreasing radius turn and have to turn and slow down, rear end is one that has to be take care for - it likes to go out more than needed.
Fedja
Fedja
Fedja
Fedja
