OEM front rotor ring replacement...
#32
You can get grade 10.9 hardware just about anywhere.
#33
I do believe that. But, I think these nuts have some kind of locking built in. Looks like the same type of crashed on one side like exhaust manifold nuts. I might be wrong here, but that is how it looks like to me!
#34
Yeah, can also find nuts like that anywhere that sells quality hardware. Obviously won't find stuff like that a place like Ace Hardware.
I wouldn't use that as an example. Grade 5 SAE hardware is nowhere near the strength I would consider for holding my brakes together.
yeah, self locking nuts.. like this
https://pitstopusa.com/i-5066438-allstar-performance-rotor-bolt-kit-grade-5-5-16-bolts-washers-and-self-locking-nuts-10-each.html
#37
I just ahd a look at the Brembo hardware I got and they too use self locking nuts.. small 12 point ones..
#38
Originally Posted by kikiturbo
You are absolutely right,.. I am not too familiar with your bolt grading. I use 10.9 or 12.9 and above on the car.
SAE Grade 8 is close to metric 10.9, "high strength"
Metric 12.9 exceeds SAE Grade 8. Probably close to F911 it aircraft hardware.
kikiturbo (Feb 14, 2019)
#39
Finally, I have found replacement for OEM stock rotor rings. For all of the others that have to use stock size/type replacement (like those that race in SCCA B-Street class), here is a solution that is cheaper than a single one from the dealer:
Spec for building the same one are located
#40
I just got a set myself a month or so ago and price went up a bit, but it is still OK.
Fedja
#41
I just got a quote just south of two bills per which I feel is very reasonable. Thank you for this information and wanted to ask about hardware you are currently running and if you could link me to them. I tried a few in this thread but only one was still active. If not no worries.
#42
#44
I did a quick look over there and found this one that looks like it might be the one:
https://racingbrake.com/rotor-hat-and-hardware-kit/
Not sure though...
Not sure though...
#45
Not sure though...
Not sure though...
https://racingbrake.com/carbon-ceramic-brake/components/ccm-10
