RaceFab wet sump pan
#349
Mike divulged some on the FB post, but not a lot. He also noted they do see pressure drops, but the way he said it made me think they weren't alarming or reason for concern.
#352
Yeah, if you follow them on FB, their whole drivetrain/engine setup is anything but a secret. Unless they're using nitrous and not telling anyone...lol.
Secret sauce would be in chassis setup and aero.
#353
no matter the baffles in the pan, a LONG right hander will starve the engine of oil. People forget that at high rpm the oil pump will take almost half litre of oil per second and most of that oil ends up on the gearbox side of the engine.. Larger oil capacity does help.. Also, the baffles on the racefab pan are quite low.. Anyway, everyone can do a simple experiment.. fill the pan with water, provided you have it off the engine of course, tilt it at 45 deg to the gearbox side... that is 1G right hander.. See where all the water goes instantly
#356
^Im not sure if it fits with the factory undertray but I can certainly ask...ill put you in as tentative Gunna have to bully you but you'll thank me later.
The pricing is listed below and varies depending on if you send in your own or have him supply one. I figure you'll be looking at around $200 for shipping, maybe a lil more.
So far looks like we have a few people potentially interested.
Heel2toe
Siluck2
Hoojan
Kyoo
evo sump modified 680nz with exchange of your factory sump and oil pickup
TOTAL $680NZ plus shipping both ways
brandnew evo sump and oil pickup 480nz
modified 680nz
TOTAL = $1160NZ plus shipping both ways
evo sump modified with exchange 680nz
x5 people $3400nz
discount -500nz
TOTAL = $2900NZ plus shipping both ways
modified 680nz
x5 = $5800nz
discount -500nz
TOTAL = $5300NZ plus shipping both ways
modified 680nz
x5 people $3400nz
discount -500nz
modified 680nz
x5 = $5800nz
discount -500nz
Heel2toe
Siluck2
Hoojan
Kyoo
#357
Damn, that's a good deal. $3635 USD for 5 new modded pans, shipped.
#359
Pickup would just bolt right on, think its 2 bolts but I forget. Ill have to find out about stock undertray; thats a good point. I figure a used oil pan should fetch idk 150 maybe so your BR pan perhaps like 250?
