RaceFab wet sump pan
#436
mine's been installed!
https://qlmotorsport.com/2018/03/12/...-sump-evo-8-9/
it clears the stock plastic undertray! It is close to the downpipe, so I'm glad I've gotten mine ceramic coated. It takes about 6 quarts to fill. the drain plug is going to splash all over the subframe brace when draining. It takes a flat 19mm, socket will not get in there (I'm looking at [url=https://www.amazon.com/TEKTON-WRN53119-Ratcheting-Combination-Wrench/dp/B01F511QCE/ or [ame]https://www.amazon.com/TEKTON-WRN57119-Flex-Head-Ratcheting-Combination/dp/B01F5124ZC/]https://www.amazon.com/TEKTON-WRN53119-Ratcheting-Combination-Wrench/dp/B01F511QCE/ [/ame]
or - help deciding is appreciated).
#437
Really? I took my plug out today it was a 22mm. And I used a socket because the damn thing was tight...
I was going to ask if anyone knew the size so I could try and order/get one made with a magnet in it. Wonder if he changed the drain plugs.
Edit it looks like its just a different plug he used on yours, flange bolt. Also you have that cross bar going across the bottom of the subframe on your car and I dont.
#438
how did you have space to get to the drain plug? the subframe brace is in the way for me. my shop didn't go super tight on it, i gave it a quarter turn once i got home. thankfully i had a combo 19-21 wrench on hand. yes, i used the 19mm side. i tested fitted with the socket first, but then coudln't fit both the wrench+socket in there
#448
Marc- how are you planning on monitoring oil temps? With my old setup I has my temp sending unit as my drain plug so my plan was to tap my new plug in a similar fashion. Do you have a seperate bung in your pan or planning on taking it from the OFH or something totally different?
#449
