Anyone mount/balance own tires?
i usually do rotate tires from left to right on second day of weekend event. so the tires could possibly move back to original spot after the 2nd day. but i cross rotate, so back to front. then i guess that wouldn't work since the back tires doesnt move on the wheel like the fronts do.
but bubble balance is cheap and easy, and does help. ive run it without balance on track before and it could shake really bad at certain mph.
I don't see how the bubble balancer is that effective. There is nothing to center the wheel on the "balancer". If it had a centering cone and a way to clamp the wheel down it would work fine.
For track driving, tires should be balanced. I can see it not being a huge deal for autocross since you're pretty much constantly turning, braking, or accelerating hard in 2nd, maybe 3rd, gear and vibrations will go mostly unnoticed. As opposed to getting up to 140+ on a 1/4 mile long straight away.
nomar manual changer + bubble balancer, paid for itself now and a lot easier to use than a HF one. i have used it on low profile 18's without a problem (after learning the technique)
Bumping this thread back up. Any issues with a simpler tire mounting machine when it comes to a really short and stiff sidewall? At what point does a more sophisticated machine become a necessity?
Given this would be solely for personal use I don't need the best tool possible but also don't want to invest in something and find out its nearly impossible and hate life every time I use it.
Well, I bought my first house 6 months ago and am a proud owner of a Rotary 2 post lift as of a couple months back. So Im slowly acquiring equipment for my dream garage.
I'd rather spend my money on a quality product since they are more robust and when the time comes for a replacement part it'll probably be easier to source. However I'm trying to establish where that line is between what is considered a quality product vs overkill for a slappy such as myself given that Im not opening up a tire shop.
EVOizmm (Apr 5, 2016)
That brings up a point i've never bothered to prove myself but i've heard more then once. So we go out and collect say 4oz of other peoples rubber EASY inside the wheels and sometimes on the outside after a session. In some cases people throw the weights because they weren't taped down. So, how many of you with sensitive bottoms (besides the hungarian ) have stopped balancing and saw no difference over the years?
i've notice difference between bubble balance vs none at all. it depends on how bad the balance is off. about a quarter of the tires i've used on the bubble balancer, i end up not even adding any weight to the wheel, since the balancer is not sensitive enough. i only add weight when it's more than 1/2 oz. but if i don't add when its more than 1oz, the steering wheel can shake pretty bad on fast sweepers that it makes it hard to steer.
I always balance my wheels, and typically rebalance before events. another perk of having your own changer/balancer.
Some race teams balance the rim only, and don't bother with the tires. But that could be because real race slicks are much lighter than most of your DOT street tires.
Like some have said, you have to know what you are doing. Some machines have some additional assist arms and stuff, but you can still scratch wheels or even ruin a tire.
I'm running a 20+ year old FMC tire changer and have been changing all kinds of stuff. I cant say I've never scratched a wheel, but if I charged what a normal shop would charge, I could easily afford to buy a new rim one in a while.
