Evo X front brake swap for Evo 8/9
#331
Yea I've been flushing fluid before every track day. $10 for a pint of 600 definitely makes things easier on the wallet. And I finally got a Motiv power bleeder so bleeding brakes is going to be so painless now.
I'm eventually going to buy some new rings for the pair of fried 5000s I have laying around but I have a couple sets of blanks I need to go through first. Almost $300 per ring isn't the most exciting thought. Earlier this week I was scrubbing the inside of the hats with some scotchbrite since there was some corrosion from the hubs on the mounting surface. Looks like they got chewed up a bit from the corrosion. Has anyone ever run a corroded rotor hat like this? I'm debating having them skimmed with a lathe to make it a true surface again.
but they do look lovely with new rotors..
#332
Yea I hate that they use those tri wing style bolts. Super annoying.
DBA says in their replacement instructions that bolts are okay to reuse but the nuts must be replaced since they're 1 use locking nuts. I was looking at the prices of those bolts and yea I hope all mine will come out without fuss haha
#338
I know a little off topic but since we are talking Evo X brakes, has anyone used the MACH V Evo X 2 piece rotor rings? They appear to be the most cost effective of the OEM 2 piece rotor ring options.
#340
Hello everyone, hope all is going well. I am a newer member to the forum and have been following this thread for a minute as I am very interested in the Evo X Caliper and Rotor upgrade as I am prepping my car for Nasa TT.
I do have a question. I am currently running 17x9 Team Dynamics wheels with 255/40/17 Nitto NT01's on them. If I upgraded, what are some 18" wheel/ tire combos that will clear the Evo X caliper and rotor (prefer to run without spacers, fenders are rolled)??
#341
Dont be so quick to thing spacers are a bad thing. To have an aggressive (wide) setup on the evo and be able to rotate (same offset front/rear), a front spacer is absolutely needed. But as for what fits the EvoX calipers, are they any harder to fit than IX? RPF1 in 18s may be tight in the 10" width but narrower have better caliper clearance. Enkei PF01 18x10.5 will clear anything.
#342
spacers are pretty much a must if you dont want to spend a fortune on wheels that will give you the correct offset and be able to rotate tires front and rear. i ran rpf1 18x10 with hoosier 275/35/18 with just slightly rolled rear quarters. just make sure you use pass through spacers with arp extended studs. don't use bolt on spacers. i've used spacers on my track car for 8 years. even pro race teams use spacers.
#343
#345
