Evo X front brake swap for Evo 8/9
#406
Also, the larger rotor (increased brake torque) makes it easier to threshold brake.
#409
Is there a good grease available that works between the piston and bore? If so, what would it be? Can it handle track use w/o poisoning the fluid?
Reduction of piston seal friction and associated pad drag seems like a low hanging fruit for performance gains.
FWIW, there is no difference in pedal feel with the Racing Brake SS pistons.
+1 for the Motive power bleeder. The only issue I have is the damn cap is a PITA to get on and off the reservoir. I get the best bleed results by pushing the pistons all the way down the bore before starting. This consistently produces a firm pedal.
#411
What? I thought the only lube to be used internal to brakes is brake fluid...
i also have the motive power bleeder, with the aluminum cap. it is a huge pita to get on and off as you've said. regardless i'll give it a go next to flush the remainder of the front calipers. what do you mean by pushing the pistons all the way down the bore before starting?
