Evo X front brake swap for Evo 8/9
#481
As a long time SCCA member, I think the SCCA has gotten several things wrong. I would say, limit cars all the way to SM on 200 TW tires and watch the participation improve. A lot of new folk come to the SCCA auto-x events on street tires only to see their tiny mods throw them into *SP, SM* or higher. We have a local series in Colorado run by the PPIR track called the Time Attack series that is exploding in popularity. They do their classing by power to weight and street tires with width limits. That series almost gets almost twice the number of people. The times are pretty close amongst the top drivers in the class regardless of mods.
If the SCCA ever redoes the rules they should just allow the following mods in all classes starting from Street.
1. Larger than stock oil pan.
2. Larger than stock radiator.
3. Oil coolers.
4. Larger and heavier than stock brakes.
5. Brake cooling kits.
6. Camber bolts and plates (the outside tire wear on most street cars is atrocious).
This really helps reliability and people that want to use their cars for dual duty auto-x and track.
3. Oil coolers.
#483
i want ss lines in street class, is that so atrocious lol
aside from that, i think improvements that improve the car without improving the performance should just be legal. but what do i know, i'm retiring the evo from autox thanks to those rules, i'm building an FS E92 M3 to keep things simple. Mini sold long ago.
quite a tangent from the original topic...
#484
I think the original topic has been discussed to it's end. I wouldn't worry about it. 😁
I agree with the rules needing a tweak. As said, if you are all about AX and build your car for it, then maybe they are okay...
But for the normal person who likes to use their car in different disciplines, they are sunk. They will not be competitive without a purpose-built car.
still....it is what it is.
I did see someone get a complaint because she had a Toyota badge on her Scion.
I thought it was a joke. Was not lol
#486
The rules arent all my favorite, and lots of time you get buried cars to keep relics relevant. Thats why I stayed in SM so long, I can do so much that its rare when I cant use more creativity instead of complaining I cant have some low hanging fruit that may not be low hanging for everyone.
#488
As someone running close to 3 deg of -ve camber on his SSC FR-S, it really isn't that bad. On softer suspension the tram-lining can hardly be felt.
#489
Does anyone have clearance measurements for the Evo X caliper? Specifically the radius from hub center to the farthest radial point on the caliper. Can be calculated by measuring clearance between the Evo X caliper and the inner diameter of your wheels, then measuring the inner diameter of your wheels at that exact point.
#490
Thanks to the original poster! I just did the upgrade this weekend. I managed to pick up a pair of calipers off a FE Evo for under $300 US and I had a set of GiroDisc Rotors already from my X. Drilling out the knuckle was a B!tch. Evo 8 on the left, x on the right Evo 8 rotors 20.9 pounds 320mmx29.8mm Girodisc 17.5 pounds 350mmx32mm Best of all with the new calipers I no longer to run a bolt on spacer! With the Evo 8 caliper I required a 20 mm space. With the x calipers I only required a 5
#492
I'm posting this here because I've gotten some useful information out of this thread for swapping Evo X front rotors/calipers onto an Evo 8/9. However, there isn't much information about doing the rear conversion other than that it cannot be easily done without a bracket of some sorts.
I was able to get some measurements for the hats and rotor thickness in case anyone is interested in doing this swap and is worried about their existing wheels fitting. Good news for you, they will fit. Here are the measurements:
Evo 8 - front hat offset 37mm
Evo X - front hat offset 37mm
Evo 8 - rear hat offset 30.3mm
Evo x - rear hat offset 30.9mm
Evo 8 - 22mm thick (girodisc)
Evo x - 22mm thick (girodisc)
Good luck!
Good luck!
#493
#495
It's well documented that the X rear caliper does not fit on the CT9a rear knuckle.
