Evo X front brake swap for Evo 8/9
#496
the rear evox calipers is not direct fit to evo 9. my understanding is that you have to widen the mounting holes on knuckles. similar to enlarging the holes on the front knuckles, but for the rear you have to make them oblong. this will be more difficult to do by hand to get the exact measurement. i dont feel there's a need to upgrade the rear brakes since most of the braking is done by the front brakes. if you're worried about brake bias, factory brake bias is usually more rearward for cars with ABS, and the system us ABS to control bias. often the rear ABS will come on before the front. if you ever have abs failure on track, you will see that the rear will lock up first. also the rear pads and rotors last considerably longer compare to front, which shows how little they are being used. btw, i'm not a brake engineer.
#498
#499
It's really easy to tell that on most modern cars that the brakes are biased by the ABS because the rear pads almost always wear out first on late model cars. The system may still have some front bias, but when real braking takes place, the ABS does the work to move more bias forward.
#500
That's easily explained away by pad volume over any bias direction. You also cant compare what happens day to day while braking 98% of the time far below threshold to what happens at the braking limit when heavy load transfer.
http://www.stoptech.com/technical-su...alance-matters
Stoptech talks about auto manufacturers being front biased here, and when adding rear bias typically reduced stopping distance is seen up to the point of instability.
We know where most auto manufacturers tune brake bias – they like our cars to be front-biased in all conditions achievable by the tires offered on the vehicle. This helps to insure vehicle stability under braking by the mass public. If we measure stopping distance of the vehicle as delivered from the showroom floor, we have a good benchmark for a vehicle with a 5% to 10% front brake bias.
The flip side can be seen by making changes to increase the amount of rear bias. Because the auto manufacturers leave a little bit of wiggle room in their designs, it is usually possible to make small changes to increase rear bias and end up with shorter stopping distances than stock. Keep in mind, however, that there is only so much of this wiggle room to play with. After a point, increased rear bias will make the car unstable under hard braking and will consequently drive the stopping distances through the roof.
#501
When I got my Evo it needed rear pads at 15k miles, fronts were over 50% still. Since then I've gone through front brakes 2 to 1 over rear brakes.
I'm not saying the bias is rearward, I'm saying that in normal/not hard/non-threshold braking the rears seem to wear faster. There may be front bias, but like you said, due to lower pad volume or just a smaller brake package on the rear, the pad wears faster. But to me, this means that the system could have more front bias (hydraulically) as opposed to relying on the ABS to affect the bias when braking harder.
I could be wrong, but that's my thinking on it.
#502
On my X, the rears are lasting forever.
That said, my X braking system felt much more stable and powerful than my Evo 8 ever did on track. So I do think the Evo X braking system is better.
#503
Ive never managed to kill a set of rear pads, but again wear isn't an indication of braking power. Its why we're going to a smaller piston in the next braking system. For small rotor AX we'll have more rear power losing about 10% front braking force, which should be a good thing, then going to 355mm rotors will move us to 5% less front which should be a good balance on track which we can balance with front pad bite (I hope)
#504
#506
The system has to have more rear bias hydraulically as this is how it works. This is done for two reasons. Firstly, ABS is used to adjust the balance, and it does so according to the longitudinal acceleration sensors. The system can lower the brake pressure, not increase it, so it has to have more rear bias for a start.
Secondly, the ideal brake bias changes depending on deceleration. The harder you brake more "weight transfer" is there and more front bias is there... Most rear bias you need under light braking.
#507
#510
The point is 100% which end locks up first...lol. If my rears lock up first, I don't want to reduce front braking power.
