Evo X front brake swap for Evo 8/9
#80
i got a used set of evo x two piece rotors with my calipers and they have last 3 times as long as centric evo 9 rotors that i used to run. although i have moved down class this year and running less HP. but the larger brakes definitely reduce pad wear and rotor wear.
#82
continuing to weigh this, but as i revamped nearly (actually i think literally) the entire brake system last year, i think i've got to give it a rest for a while. if i had thought about it a little more, i may have done it but i also run the oem wheels for my "daily" set.
i'm also running a low amount of horsepower, and i've got new front and rear calipers, both done up by racing brake with high temp seals & their stainless steel vented pistons, on DBA 5000s in the front and 4000s in the rear. i've got the air guides from whoever makes them that i haven't mounted yet. in other words, i'm hoping this serves me fine for the time being at least
#83
on the west loop at UMC last weekend we were going 125+ down the back straight out braking a light lotus on avons and gt4.
#84
if youre looking for great braking go for it. we had giro rotors and good pads with the 9 setup which worked very well and this X setup blows it out of the water.
#88
Rotor is about an inch bigger in diameter. So you get same brake torque with less clamping force. Or, more brake torque with same clamping force. Larger rotor = larger heat sink, so your brakes run cooler. Also, a larger rotor makes it easier to modulate the brakes, making it easier to threshold brake without locking the tire.
kyoo (Sep 13, 2017)
#89
so it's more the rotor than the caliper, you'd say? obviously the fitment of the x caliper assists in that, but kind of curious here.
also, ugh, more theoretical questions. on my current setup i'm using titanium shims to work as a heat shield - but in theory, this should keep the heat away from the pistons and more on the pads & rotors. given my vented piston etc., maybe i shouldn't use the shims, let the heat come out more and let the pistons vent it.. or is it still better to use the ti shims?
#90
Like I said. I wish this was the first mod I did when I started to track Evo. Everything in the brake system last longer, pads, rotors, fluid, piston seals. The only down side is 18" wheels and increased rotational mass but if you're going to do anything competitive, you need to run 18" for better tire selection anyways.
