STU #86 - 2006 Evo IX SE
#226
Sounds like this weekend was just as good as last weekend. Wish I could have done both for sure.
Listening to the launch is an interesting reminder how stock the engine is for STU compared to SM. Feels like playing old Gran Tourismo when you do a few mods in how fast it neutral revs.(edit, skip to 19sec for launch start)
What do you guys see for accel G's?
#227
https://youtu.be/54tdk1LomII?t=20s
#228
You've inspired us to rethink our setup a bit and raise the ride height. Our car simply refuses to take a set on bumpy concrete and plant itself properly in transitions or sweepers, so much oscillation it's crazy. I'll have to post up some video and compare our in-car to yours... hop induced understeer sucks ;-)
#229
Nice to catch up with you again as well! and super fun racing as usual.
#230
Im going to be doing some testing to see if its possible that big swaybars might be a culprit on my car for the on throttle hop. Not sure what you guys run for bars, but in my case Im starting to wonder if it could be a cause. Will be trying some crazy rates and tiny bars as a test in the near future.
I'm (mostly) convinced now it's because we've had the front of our car too low from day one, with the front roll center in the dirt.... but I don't have any math to back that up. We've got our spring wheel rate numbers, bar rates, roll stiffness front and rear, NF front and rear, etc... but is there a handy formula\modifier for the effects of ride height, specific to our chassis? Something like, if your roll center is is ideal it's a value of 1, and then depending on ride height that value changes and modifies the roll stiffness calculation, somehow?
Our original setup guy was always about keeping the CG low, with the bumpy Packwood, and Crows, and Lincoln to an extent, I'm not certain it's doing us any favors though.
I was also wondering if NF played into it, or the delta between the front and rear NFs... but, over the years we've moved that delta around a lot as well, from 0 (same NF f/r), to similar to stock and then up to 0.5 stiffer rear, and in talking to Jimmy it seems he's running an even bigger delta front to rear, and yet his car looks pretty good over them bumps
#231
If we think about the root cause of hopping, something is causing an un-dampened reaction. For a while I thought it could be caused by the tires itself but I'm not sure I feel that way anymore. Seems some experts expect the tires to be adequately dampened and pretty stiff. If the rear is a primary source for it (in my case, with high front RC, I think this is correct) then the rear tires really probably aren't the culprit.
So that leaves Swaybars and geometry conditions. Swaybars are an easy test, disconnect, does it still do it? I should have thought of this in crows where we got hopping on power. The effect could be additive also and caused by multiple things, but at least I would have seen one of the variables.
The next option would be geometry conditions. There I think 2 things could be causing it. One would be RC is so low that the outside is being driven down (anti-jacking effect) due to geometric conditions. That would probably be more seen up front where RC drops about 3:1 with ride height. Rear RC when dropped at my ride height may only have the lower control arm angled up 1/4" (just barely). That shouldnt cause that much effect though. RC should be roughly ground level, though will be working on rear geometry here really soon.
I also suspected squat geometry but the rear trailing arm, even lowered, has a lot of anti squat built in. So much so, at stock right heights that angle must be pretty steep. Is that a rally thing maybe? Go look at the angle of yours, its pointed up pretty good. So thats not really an issue.
Circling back to all the options, I would guess Shocks just not adequate for your rates, Front roll center, and rear swaybar. We do know going softer springs and higher ride height seems to fix things, but thats not a reason to not keep trying to solve it with stiff springs and low ride heights.
#232
#233
Wasnt that the first things I put down
Though, there does seem to be something else really going on. Not everyone with hop is going to be equally excessively under damped. In crows, I did try to crank my shocks up close to max with starting around the middle, hop barely changed.
Another though, I use to get corner entry hop and that is now completely gone with my uprights fixing RC. The hop I see now is fully felt in the rear outside bucking down on heavy accel loads in corner exit. Unfortunately I dont know if I'll be able to root-cause the issue because I dont have enough accel traction on our normal Asphalt compared to the ultra high grip of crows. But I bet if I raised the rear the hop would reduce.
#234
On a more serious note, there are two parts of the shock movement that could cause this. One is that we've mention above for not having enough rebound and allowing wheel to drop down faster than it should. The other side is when wheel is going up over the bump - too much of low speed compression (and/or too high level for high speed compression adjustment, depending of the shaft speed) would raise the car and create another body movement that you don't want to have there either.
#236
#237
We currently have the stock front, drilled stiffer, and a hotchkis rear on soft, and higher spring rates; we've tried the opposite as well (Whiteline bars, 150lb softer springs)...
We swapped back to Bridgestones to start this year (with the softer rates) and still had the hopping over bumps and on corner exit, but not as bad as before - really the big change was going back to Nexens, so I suspect the stiffness of the tire also plays a big part in all of this (assuming that the Nexens are a softer tire, in terms of tire stiffness). Though the hopping isn't completely gone, the car does handle bumps a ton better and doesn't have trouble getting the inside rear down on power.
My friend Ric got pictures of run groups 1 and 4 from the Crows Tour:
#238
