rear brake pad retainer pin fall out??
Old Sep 18, 2017, 04:07 PM
Meathooker's Avatar
anyone else have this problem? pretty sure its due to needing more clearance on the rear pads and them rubbing on the two piece rotors but it seems like we should have a pin similar to the STI's.
do you guys run sti pins? will they work in ours?
Old Sep 18, 2017, 04:18 PM
Received 1,384 Likes on 1,317 Posts
One the members posted this 2 years ago, as it happened to him as well. One of posts noted the diff between the STI cotter pin vs our clam shell type pin
https://www.evolutionm.net/forums/mo...-fall-out.html
Old Sep 18, 2017, 04:30 PM
LetsGetThisDone's Avatar
Received 1,542 Likes on 1,321 Posts
I drilled the tip that protrudes from the caliper body, and I safety wire the pins together.
Old Sep 19, 2017, 04:49 AM
Balrok's Avatar
Ditto, but I used clips.
... but for some reason my IBSRV hosted pic of the pin is now a pic of some snowed up Evo in that thread....
Old Sep 19, 2017, 05:03 AM
honda-guy's Avatar
this happened at the track on an evo before. we push an allen wrench through and bend the end over as a temporarily fix and got through the end of the event.
Old Sep 28, 2017, 02:20 PM
amn_suazo's Avatar
I did the same thing after my pins fell out my first track day. Problem solved
Old Sep 29, 2017, 08:07 AM
Lol, I drilled them for you..
Old Oct 2, 2017, 12:42 PM
amn_suazo's Avatar
Also yes lol. Was referring to the OP how quick and easy this fix is
Old Oct 2, 2017, 02:49 PM
Butt Dyno's Avatar
Location: Why do they always call the Evo the Dark Side?
LOL, this just happened to me a month ago. I thought I was crazy until I found that thread
I just replaced them with new OEMs but I'd love a more permanent solution. Comparing the old spring to the new spring, I think they just fatigue over time.
Old Oct 3, 2017, 08:08 AM
Balrok's Avatar
Fixed my link:
Old Oct 3, 2017, 08:37 AM
heel2toe's Avatar
I wonder if this is actually related to heat causing expansion of the caliper allowing the pin to slide out, or if it's just happening to track junkies being that we're the ones going through brake pads all the time so the clips are becoming worn out?
Old Oct 3, 2017, 11:55 AM
Balrok's Avatar
Heat and vibration mostly, don't see that kind of heat until you're tracking it.
Old Oct 4, 2017, 09:06 PM
amn_suazo's Avatar
It happened on my very first track day with my first evo. Was still on what ever rear pads were on the car when I bought it, and it was a show car so I can't imagine it being from wear. Design flaw on Brembo, that's my opinion
Old Nov 17, 2017, 03:46 PM
EVOlutionary's Avatar
We had this happen over and over and over again during OLOA in 2011. Changing out the brake rotors fixed it and it never happened a single time again. Our conclusion was a warped or not fully seated brake rotor (crud between the rotor and hub) that lead to vibration and the harmonic was the perfect frequency to push the pins out. We could replace them and they would fall out in 3 laps.
ReidFletcher
Jun 10, 2015 04:34 PM
nytalonTSi
Jul 24, 2012 08:48 AM
TigOLDBiTTies
Apr 27, 2012 01:11 PM
toysgetsmoked
Oct 17, 2010 11:01 AM
Girodisc Martin
EvoX 'For Sale' Suspension / Brakes / Handling
59
Sep 24, 2008 08:37 AM
Quick Reply: rear brake pad retainer pin fall out??
