Rear Toe Arms who uses what
#31
well here are the drawings for the parts that need machining. I presumed you will buy tube ends. This is setup for 14 mm rod ends. Your machinist might want to adjust the size of the part that goes inside the inner 14 mm rod end by a few 1/100 mm, inside mount, so that it fits easily..
The part that goes inside the knuckle, the cone part, doesnt have to be that long. The outer mount is held by the bolt and the friction, the cone part is there just to support the bolt and provide location when you are mounting it.. It is by no means a press fit.. it fits a bit loose actually..
if you have any questions, shoot..
files:
http://www.bib-nakladnistvo.hr/CARPR...OD%20PARTS.zip
files:
Bee-Raddd (Jan 23, 2018)
#34
files:
files:
Thanks so much for this! will get onto it and post some results! i need to track down some 14mm rod ends. the place i normally use only has imperial rod ends and weld in stubs so got to track down some metric stuff. got the chromoly bar. although ended up with 1.5" bar but it was free haha so ill take it!
#35
you can always adjust it to the imperial stuff.. the only issue are the end bolts..
#36
All the other bits r easy. its the machining thats the missing link! ill have to get onto finding somebody who can chuck it into a cnc for me haha
#37
hey Kiki
Can i get away with just using high misalignment washers on the rod ends or do i need to get those items you sent me cnc'ed im just trying to figure out exactly where those bits are used?
#38
problem is the rod end is 14 mm and inside bolt is 12 mm so if you use high misalignment washers you will need to sleeve the rod end... if we are talking about the inner mount..
KFC-AWD
Oct 28, 2015 12:59 PM
allevolution
Oct 24, 2013 06:50 PM
EvilTechnology
Nov 13, 2012 09:56 PM
overdrive1
Apr 1, 2011 05:36 PM
