Rear Toe Arms who uses what
Hey All.
Whos got custom or aftermarket rear toe arms?
What brands do u recommend etc? I need to upgrade mine as i cant get camber reqd without losing toe.
Hardrace is the first and cheapest option available but worried they might not be very good?
I just bought some Hardrace ones, but haven't driven the car yet with them. Doing some mods to the front of my car for increasing caster and track width, so once done next week, will get it in for a wheel alignment and see how they go.
Hardrace are on special at Redline until the 26th
I just did new tube section with hex in the middle so I can hold it better when adjusting, and will uprate the bolt to 12.9 instead of 10.9 as it is now..
I will weigh both today and let you know.. I was never interested in weight becaue the originals cracked so I nedeed new arms.. We could make it lighter with aluminium spacers but I am not sure if it will be hard enough to hold the bolt tq
Rod ends are FLURO Motorsport .. those are PTFE lined and have reduced clearences
ok, I checked... it is 100 grams heavier than stock item... but it does have sphericals on both ends (14 mm ones) instead of rubber on OE.. I think it is overbuilt a bit but I sleep well. It could be made lighter by making this adjustment ring thinner, and maybe doing the adapter that goes into the knuckle out of alu or Ti..
here is version 2, I made this TIG welding jig to get nice welds on tube ends..
What size tubing/wall thickness is the tie rod?
v2 is 30x1.5 mm, V1 was 32x2 mm.... everything is Crmo... 25crmo4 or 4130 in US
I think the inside chassis mount will fail before anything in that arm..
kikiturbo (Dec 26, 2017)
a lighter solution would be something like 25x1.5 tube with 12mm rod end on the inside, maybe even 12 mm on both ends.. that would work too... However, 14 mm rod end will have longer service life and is easier fit with the upright, both of which were considerations....
much lighter solution would be a fixed toe arm, with no adjustment.. and that could be done easily... however, having toe adjustment on the arm itself gives the opportunity to run the inside chassis adjusters fully in which lowers the bump toe change a bit... Also with the way the outer asttachment is done, via rod end, you could easily adjust bump toe change with some spacers...
oddly enough my front arms are not adjustable.. not in the usual way anyhow..
taper is for location, flat holds it in place really, although both are nice fit...
I supposed it's worth mentioning that Mooresport sells these extremely affordable toe arms lol: http://mooresport.com/en/street/131-...et-billet.html
