Ohlin Bearing Replacement, Possible New Source?
Hey guys, I have a bad Ohlin spherical bearing and been looking for an alternative source other than $80 each from PSI and so far have only found one possible alternative on Alibaba.
https://www.alibaba.com/product-deta...147e2041XadHfk
None of the standard bearing companies makes an 18mm ID bore matched with a 33mm OD. 42mm seems to be a standard for this size which is obviously useless for us, doh!
If we had enough people interested we could do like a set of 4 for $100 or something like that and I would just eat the rest to get another option. Would have to eventually get paid back for these of course but not looking to turn a profit.
Anyone see any other places? I've also thought about just making a new bearing housing for myself but the 18mm ID to keep same spacer nut makes the 42mm OD necessary and that becomes a different problem.
Huh, that is the same exact part # as the NMB bearing that can be sourced locally. I wonder if they are the exact same however I thought NMB was a US company and were built here as well?
Im currently using CDR plates which has a slightly different carrier bearing. However, Im temped to pick up a set of your plates as I have essentially brand new Ohlins top hats that I could use in conjunction with them.
What I would love to find out is how the quality of the parts differ as a cheap spherical seems like itll be useless in short order.
FWIW if it helps in your searching since I spent a while looking into this in the past what you're after is the following:
Inner 18mm
Outer 33mm
Ball 20mm
Race 16mm
Inner 18mm
Outer 33mm
Ball 20mm
Race 16mm
I've got a single bearing that I'd be happy to sell. Purchased it to replace a blown up bearing, then realized the whole camber plate was taco'd and the bearing wouldn't fit. Ended up being cheaper to get new Ciro's than replace the Ohlins parts.
PN 05536-51, 16mm x 30mm x 19mm. Make sure of the size you have / need.
List price $229.03 - make me an offer!
I do know there are two version of the bearing mounts, theres a 10-bolthole and a 8-bolthole bearing housing. The 10 bolt seems to be on older DFV and probably R/T and also on my Flags. I dont know when, but at some point they removed 2 holes.
Im wondering if the bearing size changed too? My bearings (Old DFV and Flags) are 18mm ID and 32mm OD.
Oh dang, well I have no other thoughts but update us if you find a place.
Edit: Have you seen the replacement pin for the Flags I have? Have you checked if your pins are in tact? I havent heard of anyone not breaking them, but I did get some nice scuffed up canister pics from a guy today in EU with a set and broken pins.
Ok cool. I need to put more effort into getting the knowledge of the breaking pin and damage that can happen. I was pretty annoyed when I got my first set and found the out about the pin issue but now that's fixed they're amazing shocks.
These are from a guy Im talking with en EU for various parts.
I just looked at my invoice from PSI and they replaced the reservoir tube and internal membrane. I belive they had to wait to get those and some other parts from Japan. This was 4 years ago, they might still have some of the parts. It was actually 9 months turnaround on the rebuild.
